Classic Audi » Technical » Technical Info » inlet mani flow rates? wanted
Old 28-11-09, 01:15 AM   #1
Gaz
Gaz's Avatar
Question inlet mani flow rates? wanted
dunno if this is the right section to post this, but i want to know the flow rates and other related information(volume etc) of various inlet manifolds.
I was hoping someone might have a list of flow rates for comparison purposes.
I think 4v6 had some info in this area?
But I guess the two manifolds I really want to compare are the 10 valve turbo inlet manifold (was there only one design?) verses the naturally aspirated KV inlet manifold.
Old 28-11-09, 10:13 AM   #2
4v6
Hi Gaz, got your pm.
Ok, i presume youre interested in knowing how much the intake manifold flows at the throttle body?
Id need to do a blow through test on both types of intake and see what happened.
From some of the tests i did on Emjays carbed intake iirc, i found the turbo intake flowed not much better than the carbed manifold.
I do have a turbo intake i can test but i dont have a KV version.
Ill run a flow test on the turbo item shortly (discharging thru all the ports) so we'll get a total flow figure for the manifold.
Flow distribution will definitely be different for the KV item id say as it flows in from the other end.
7a inlet elbow audicoupeparts Parts Wanted 3 05-12-09 11:44 PM
WN carb inlet manifold knobstar Parts Wanted 5 29-12-08 04:46 PM
New Vehicle Excise Duty Rates Coxy General Chat 9 29-11-08 10:20 AM
Inlet manifold. Booty Engine 4 05-09-08 06:16 PM
Jetronic Fuel Metering Head / Air Flow Meter randall977 Parts Wanted 5 17-12-07 04:26 PM
