Classic Audi » Technical » Mech/Tech » Wheels & Tyres » vredestein sportrac 3
Old 02-09-09, 11:50 PM   #1
Gaz
Gaz's Avatar
Lightbulb vredestein sportrac 3
has anyone got these on a car? reason i ask is, if you happen to be running a 195 width could you please measure how wide the top of the tread is before it tapers away? As i've heard that different makes/models of tire can vary a bit in there 'true' width when compared to the identical tire size of another manufacturer.
For example, the tires that came with my borbets seem quite [square] and seem wide for a 195/50/16 tire when compared to the 205/50/15's that were on the GT.
I'm just wondering if these vredestein sportrac 3 might have a more favorable true width and side tread taper, as these were the tires i would most like to buy.
Hope that all made some sense.
cheers again.
Gaz
Old 03-09-09, 07:13 AM   #2
20vcqdriver
20vcqdriver's Avatar
Lynn's A4 uses 205 width sportrac3, They have a good tread pattern and grip well wet or dry but the true width is a bit less than 205 and do 'taper' as you put it.
Vredestein SPORTRAC 3 cheapest place to buy? Gaz Wheels & Tyres 4 18-03-09 11:48 AM
