Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » Rear light cluster gasket/mastic??
Old 15-08-09, 04:51 PM   #1
geordie1980
Default Rear light cluster gasket/mastic??
Just removed the rear light clusters on my '83 80 saloon and the rubber gasket stuff (like blu-tac sort of) is in a bit of a mess. Anyone know what this stuff is and where to get it??
Cheers
john
geordie1980 is offline   Reply With Quote
Old 15-08-09, 05:01 PM   #2
Yes any audi / volvo dealer or good body shop
Old 15-08-09, 05:37 PM   #3
4v6
Butyl Tape is the name of this stuff iirc.
Old 17-08-09, 06:03 PM   #4
BigT80
Cheers
john
I've not been able to find the proper stuff - usually comes 'wrapped' in a sort grease-proof brown paper, so I've used 'Dum Dum' paste in a yellow tin. About £10 for 1kg from someone like 'Frost' - they do smaller tins too. They you say you have to use it within a year once opened. but mine is fine after 18mths & you could do a dozen lights with it, so it's cheaper. It isn't quite the same, but it works just as well IMHO. Cheers. G
BigT80 is offline   Reply With Quote
ns rear light 1984 coupe Flash Parts Wanted 1 24-10-09 10:49 AM
Cabrio - 1995 Headlights & rear light panel BigT80 Parts Wanted 4 05-04-09 10:02 PM
Ur Quattro/coupe, smoked rear light n/s Steve Hope Parts Wanted 3 08-02-09 09:22 PM
Rear light unit poopcoupe Parts Wanted 10 22-11-08 04:17 PM
Audi 80 (B2, type 81) 1982 rear passenger door & rear pasenger side light sprig Parts Wanted 1 28-02-08 12:36 AM
