Classic Audi » Classifieds section » Parts For Sale » Full Coupe Quattro typ85 ABS kit
Old 14-08-09, 05:38 PM   #1
Puglife
==>PUGSPORT!<==
Puglife's Avatar
Default Full Coupe Quattro typ85 ABS kit
This kit is off the rally recreation, its not needed as i've never been a fan of assisted braking... Man needs to know when he's locking up....
The kit is everything from ABS side of things, 4x wheel sensors, the ABS module for brake lines, the full incar loom with ABS ecu and wiring for the ABS bulb, also has the ABS switch. This is all intact and straight out of the car... I can offer help with fitting side of things if someone is confused. I'll label up everything so its visible where it should locate in the car. This is the same system fitted to Coupe Quattros (type85) and UR Quattros. The system had no faults and I simply removed and boxed it up.
I have a second kit which is off my 1986 UR quattro and this is also a complete kit.
I'm looking for £150 + postage for each of the kits. This reflects the fact its a complete setup and you would probably pay alot more for individual parts. Photos available on request.
Old 24-09-09, 02:53 AM   #2
Gaz
Gaz's Avatar
mine has ABS already. but just out of interest, did you also remove he accelerometer from under the rear seat?
Old 24-09-09, 05:40 AM   #3
Puglife
==>PUGSPORT!<==
Puglife's Avatar
The accelerometer is only present on type89 not type85 cars.
Old 24-09-09, 08:31 AM   #4
Cornholio
The later type 85's got it too, my 1988 cq (type 85) has the accelerometer......
http://www.kvquattro.com/tfa/electri...ntrol_unit.htm
Cornholio is offline   Reply With Quote
Audi Coupe Quattro (typ85) White Puglife Cars For Sale 2 01-02-10 05:59 PM
Typ85 Coupe Puglife Cars Wanted 5 18-10-09 10:31 AM
Full interior for my '89 Coupe please... lewiswilkinson Parts Wanted 7 27-04-09 10:29 AM
Audi Quattro Coupe Typ85 Puglife Cars Wanted 3 04-01-09 02:10 PM
1985 Typ85 90 quattro in gleaming alpinweiss! Coxy Cars For Sale 18 14-02-08 10:21 AM
