Classic Audi » Community » General Chat » Mac G4 PSU dead
Old 19-07-09, 09:25 PM   #1
Default Mac G4 PSU dead
The PSU on our G4 Quicksilver powermac has died, well I think it has, it stays on for about 5 minutes then turns itself off. Everything works well beforehand however.
It is over 7 years old so has had a good run so far (far far longer than a PC would have lasted without upgrading everything twice, like Trigger's broom........).
Anybody know:
can you fit a PC PSU with a link cable as some of the pins are slightly different?
Where I can get a 2nd hand one (tried ebay so far).
Can I take out the hard disc (40GB) and put it into some kind of caddy so I can copy the data off it???
Cheers
Steve
Old 19-07-09, 09:51 PM   #2
I don't think it's PSU. Or it is much complicated than standart ATX ones. When standart PC ATX PSU dies, it just doesn't turns on. U push button, but only that can happen - fan can start spinning for half second. Is there everything ok with CPU? Isn't there excessive dust, dead CPU fan or detached heatsink?
I don't know what kind of filesystem uses mac os x, I only think that there isn't any of microsoft used outdated filesystems, so win will be unable to copy something from your HDD. At last without any third party addons/drivers/utilities.
P.S. About "unability to use 7 years PC without upgrade" - bullshit, microsoft crappy windows isn't only os for PC
Old 20-07-09, 09:13 PM   #3
OK.
I will take the case off (well open the door ) and check the CPU fan and stuff is OK.
I can get the PSU repaired here for £40:
http://www.cpsupport.co.uk/quicksilver.htm
And as the hard disc is an ultra IDE 66 something, I can get one of these and turn the hard disc into a USB drive, no sweat with MAC OS X......
http://www.ebuyer.com/product/136250
Old 20-07-09, 09:16 PM   #4
Ah, u have case closed with warranty sticker, right?
Old 20-07-09, 09:21 PM   #5
er no.
To open a G4 case you just pull the handle. I'm sure even you could manage it.
http://docs.info.apple.com/article.html?artnum=42687
This was in 2001 when PCs still had fiddly screws at the back and sharp metal cases.........
I have opened the case about 3 times to press the internal reset button, but that is it. No need to open it more........
Old 20-07-09, 09:22 PM   #6
I don't talk about your G4. I'm talking about computer which u wanna use to copy data from HDD.
Old 20-07-09, 09:27 PM   #7
er no.....
click here:
and read about it. I will take the HDD out of the G4, put it into the product above, and it turns a HDD into a USB HDD, so I will plug the drive in the case into my other Mac using a USB cable..........
Old 20-07-09, 09:29 PM   #8
I don't need to read about it, I know what it is. U wanna say that your G4 have paralell ATA HDD and un can't plug it into your "other mac"?
Old 20-07-09, 09:34 PM   #9
Not when it is a Macbook (laptop)............ which has Serial ATA apparently, whatever that is.
Old 21-07-09, 01:57 AM   #10
5potnoodle
OCD member
5potnoodle's Avatar
Sounds like an overheating issue. They probably have thermal cutout protection built in. Take the PSU out, take the lids off and blast 7 years of dust out with a compressed airline. Put it back together and try it. Nothing to lose...
Current:
99 Subaru Forester S-Turbo Auto - interesting... but it's not a quattro
91 Reliant Scimitar SST 1400 - no.39 of 42... something for the weekend
Previous:
Two consecutive 1989 Audi 200 Quattro Turbo Avant, 1B
1990 Audi 100 SE Avant, NF
1986 Audi 100 CD Avant, KU
1987 VW Passat GL5E Estate, JS
"Honorary" triple member of the 200,000+ Club
Audi 200 in the UK (legacy website)
Classic Audi member no: 258
5potnoodle is offline   Reply With Quote
Dead before their time stuartmmcfc General Chat 36 30-01-10 08:13 PM
H from Steps is dead.... Coxy General Chat 8 15-09-09 11:21 AM
Limey is dead! Help! SteveCat General Chat 15 10-08-09 01:42 PM
Is everybody dead? poopcoupe General Chat 28 04-07-09 10:40 AM
