Classic Audi » Classifieds section » Parts Wanted » 7A cams
Old 03-07-09, 08:18 PM   #1
jogi730
jogi
jogi730's Avatar
Default 7A cams
As above really, needed fairly urgently (ideally by Monday).
Can't remember if it's the inlet or exhaust that you need for better low down spool with higher lift?
As some know I want to do my engine this time so it's spot on. As it is being mapped on engine-dyno out of the car, it will not be too difficult to try different cams/combinations.
If somebody would be good enough to 'borrow' me some cams on sale or return basis, that would be fantastic.
Failing that, has anyone got a pair at a reasonable price for sale?
Many thanks
Chris
PS. What is a reasonable price for a pair of cams?
jogi730 is offline   Reply With Quote
Old 03-07-09, 09:44 PM   #2
20vcqdriver
20vcqdriver's Avatar
Many thanks
Chris
Gave my 7A cams to puglife I think. Its the exhaust you need to give the car massive top end performance at expense of a small loss at low rpm, but if mapped right its worth it...
Better not use inlet as too much overlap for a turbo engine giving slower spool times...
Old 03-07-09, 09:49 PM   #3
jogi730
jogi
jogi730's Avatar
How about ADU cams (RS2?) Is there a better solution?
Many thanks
Chris
Old 03-07-09, 10:31 PM   #4
20vcqdriver
Many thanks
Chris
RS2 inlet same as ABY/3B, exhaust not much different to 7A. Wish I had kept mine now I am looking at a GT2871 after the bottom end rebuild completed...Fast spool up and 350+bhp the aim...
Where to buy schrick cams? Kit Engine 4 23-03-09 02:14 PM
Cat Cams knobstar Technical Info 8 02-03-09 04:16 PM
cat cams - apologies for re-post! knobstar General Chat 3 24-10-08 06:46 PM
