Classic Audi » Technical » Mech/Tech » Engine » kv engines
Old 24-04-09, 06:21 PM   #1
ferris360
ferris360's Avatar
Default kv engines
firstly is it possible to raise or remove the rev limeter on them mines in a 1989 audi 90
also and good tricks on getting bit more power out of it i dont mean major work stuff like port n polish or cams just little bits for now i know on my old polo gt there where loads of bit you could remove / blank off smooth out to get some small gains any ideas welcome
and drill the air box dont work as i found when it wont run lol
ferris360 is offline   Reply With Quote
Old 24-04-09, 06:40 PM   #2
I don't think you'll make any massive gains, but you will improve throttle response with a modified airbox and decent filter, just make sure it's getting cold air, not hot. Then, go for decent ignition, leads, plugs etc... Then look at the exhaust, that'll help...
Taking the revs to 6.5k is about all you'll get, (rotor arm change), this'll probably make no extra power without a cam change though.
Decent oil, decent oil adative (slick 50 etc), clean injectors.
Run 75/25 Super to standard Unleaded, octane booster (max dose) fuel injector cleaner (minimum dose)...
Think good air, strong fuel, bright spark....
Oh... And sling as much weight out as possible....
Old 24-04-09, 07:52 PM   #3
20vcqdriver
20vcqdriver's Avatar
Not worth removing the rev limiter unles you change the cams etc as the later 5 cylinders in the series 3 cars ran out of puff after about 5700rpm anyway. well worth removing the CAT on the exhaust, perfectly legal on an 89 car. ALso as stated, decent fuel, decent plugs and leads decent filter and taking a chunk out of the bottom of the airbox should not make any difference to running/ starting unless you pulled something off in the process. Chopped the bottom of mine and added a stainless chute to guide cool air in. Good luck
pair almost complete KV engines audicoupeparts Parts For Sale 0 19-12-09 05:57 PM
VAG shared engines naffa General Chat 3 25-11-09 06:00 PM
S1 engines golf kerker21 General Chat 0 17-10-09 08:06 AM
kv engines x2 audicoupeparts Parts For Sale 0 26-08-09 08:07 AM
90 type 81? engines stoop44rio General Chat 3 30-03-09 10:09 PM
