Classic Audi » Technical » Mech/Tech » Engine » Engine transplant
Old 06-10-17, 01:27 PM   #1
Mar5den
Default Engine transplant
Hiya all my names scott aka fluffy ive got a audi 80 on a d reg and im looking at put the famous 5 cylinder engine in is it a straight bolt in and can i use the shafts thats on the car ect??? Thanks in advance
Mar5den is offline   Reply With Quote
Old 06-10-17, 04:56 PM   #2
4v6
Best way to do this is to use a donor car with everything you need, maybe a front clip with the gearbox etc.
Old 06-10-17, 05:04 PM   #3
Mar5den
What do i need
Old 07-10-17, 08:33 AM   #4
The Duke
The Duke's Avatar
I do happen to have the complete front assembly (engine, gearbox, drive shafts, suspension, brakes etc.) from a KK 80q if that helps? Also got the same in bits from another KK and a 90q
The Duke is offline   Reply With Quote
Old 07-10-17, 08:36 AM   #5
Mar5den
The car is complete i was just wanting to know if i can use all existing parts in the car??
Old 07-10-17, 08:39 AM   #6
The Duke
The Duke's Avatar
My understanding is it's simpler to drop the subframe and transplant the lot rather than using the 4 cylinder parts. But if you do just want an engine & box I just happen to have them to 😉
Old 07-10-17, 01:58 PM   #7
Mar5den
Ive got an engine and box i got them.both rebuilt but i mite be intrested if the price is right so could i just use what in the car???
Old 07-10-17, 02:42 PM   #8
quattrodave
You need the 5 cylinder subframe from a B2 as its different to the 4 cylinder subframe in the car now.
Old 07-10-17, 08:30 PM   #9
Mar5den
Are you 100% sure as the bloke i bought the engine off said the subframe of the 4 cylinder is identical
Old 07-10-17, 11:38 PM   #10
quattrodave
From memory (like 20 years ago) 4 cylinder engine has the engine mount pressings on the front of the subframe these are missing on the 5 cylinder cars and as I never owned a front wheel drive B2 (only owned B2/3/4 quattros) the 5 cylinder quattro cars have the gearbox mount pressings on the rear of the front subframe like the B3 cars.
