Classic Audi » Technical » Mech/Tech » Engine » Cleaning injectors
Old 01-10-17, 07:05 PM   #1
pastit
Default Cleaning injectors
Hi guys.
Anybody ever used a ultrasonic cleaner to clean the injectors ?
https://www.amazon.co.uk/James-Produ...ra%2B7000&th=1
pastit is offline   Reply With Quote
Old 01-10-17, 07:13 PM   #2
sinbin5t
sinbin5t's Avatar
Hi Pastit,
I take it you checked them and they were no good then.
Old 01-10-17, 07:24 PM   #3
pastit
Taking them out tomorrow. But just wondering if they are blocked would a ultrasonic cleaner work or shall I just purchase new ones ?
Old 01-10-17, 07:36 PM   #4
sinbin5t
sinbin5t's Avatar
If it were me i would get new one's if they are blocked, check the fuel is clean after the filter too though.
Old 01-10-17, 07:41 PM   #5
pastit
I'm going to replace the filter also.
Old 01-10-17, 07:42 PM   #6
sinbin5t
sinbin5t's Avatar
Old 02-10-17, 05:07 AM   #7
Colin Aitchison
Colin Aitchison's Avatar
I used a spray can of carb clean, comes with long and short spray cap pipes, I used the short one and held the fuel injector in my left hand and pushed the short pipe into the inlet end of the injector with my right hand and gave it a squirt, the pressure from the carb clean can was high enough at first to open the injector and let the carb clean through, all 5 of my injectors had 5, 6 or 7 little fingers of fuel coming out of the injector at first but after a couple of squirts
it became a mist, it worked for me and the carb clean was under a fiver.
Colin Aitchison is online now   Reply With Quote
Old 02-10-17, 06:32 PM   #8
sinbin5t
sinbin5t's Avatar
Sounds a good idea, got to be worth a try before spending a lot, good info Colin !
Old 03-10-17, 11:18 AM   #9
rangerovering
rangerovering's Avatar
If the above doesn't yield the results you want I've used Injectortune a few times now and have been pleased with their work
rangerovering is offline   Reply With Quote
Old 03-10-17, 05:40 PM   #10
sinbin5t
sinbin5t's Avatar
Sounds like a cheaper alternative to new as well
