Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » door mirrors
Old 03-08-17, 04:03 PM   #1
jackster
Default door mirrors
hi can anyone shed light on how to remove the door mirrors on the 80 b4 saloon cheers
jackster is offline   Reply With Quote
Old 03-08-17, 04:10 PM   #2
You need to rotate them to reveal a pair of bolts in the base which secure them on the door.
Be careful with these. Only a 4mm allen bit and they're a soft material
1991 90 quattro
Old 04-08-17, 02:00 PM   #3
jackster
cheers mate give it a try later,will this take everything off as i will be respraying the car.
Old 04-08-17, 02:05 PM   #4
sinbin5t
sinbin5t's Avatar
Get loads of WD40 sprayed down there before you try and leave to soak for a while, as mentioned the bolt heads can be like chocolate, if you round them out it's a drilling out job then.
After these are taken out the whole mirror is removed.
Old 04-08-17, 03:47 PM   #5
jackster
yep 2 bolts stuck solid and rounding off, plenty of wd40 had been put on,and its the same bolt on either door so must be a problem with them,gonnae drill them out tonight after tea ,is there a wiring connection to be taken apart after all this and is it in the door skin or mirror cheers.
Old 04-08-17, 03:53 PM   #6
sinbin5t
sinbin5t's Avatar
There is wiring in the door and the mirror so be careful, just drill the bolt head off, unplug the mirror after you lift it from the door and then tuck the wiring in the door out of the way if you need to drill the rest of the bolt out, once the heads came off mine the rest just unscrewed.
Take your time and you will be okay
Old 04-08-17, 03:56 PM   #7
jackster
thanks for that mate well appreciated cheers
Old 04-08-17, 04:00 PM   #8
sinbin5t
sinbin5t's Avatar
No prob's, if you have to drill the rest of the bolts out remove the doorcards and hoover the swarf out, check none is in the window mechs too, no rust in the door bottoms then and no jammed window mechs.
Old 04-08-17, 06:48 PM   #9
jackster
yep 2 bolts jammed solid ,drilled out 1 was a right bugger had to drill halfway down the mirror shaft to release it, cleaned out the door bottom now sitting down with a can of magners, well you have to on a friday night if not going out cheers guys.
Old 05-08-17, 11:58 AM   #10
sinbin5t
sinbin5t's Avatar
