Classic Audi Technical Technical Info » Audi s2 headlights
Old 18-05-17, 08:14 PM   #1
overthehill
Question Audi s2 headlights
Hi are the headlight manual adjusters replaceable or repairable on my S2 Quattro like they are on my UR Quattro . Or are the adjusters on ellipoid and normal interchange able
1995 S2 QUATTRO
1985 WR QUATTRO
1988 COUPE GT
1989 100 QUATTRO AVANT
1978 DOLLY SPRINT
1980 DOLLY SPRINT
VW T5 TRANSPORTER
CITROEN C2 300K+
overthehill is offline   Reply With Quote
Old 18-05-17, 08:42 PM   #2
Headlight leveler motors, according to catalogue, are the same stuff as could be found in all B3's and all mk2 coupes. Repairable? Well, they can surely be taken apart, only the question is what will be inside - if it's just stuck, why not regrease it, but if there's extensive water damage...
Old 19-05-17, 05:54 AM   #3
overthehill
ok thanks for reply electric adjuster works i meant the 2 beam adjusters ,put allen key in turn but no movement of lights.
1995 S2 QUATTRO
1985 WR QUATTRO
1988 COUPE GT
1978 DOLLY SPRINT
1980 DOLLY SPRINT
VW T5 TRANSPORTER
CITROEN C2 300K+
Old 20-05-17, 10:08 PM   #4
quattrodave
Nylon gears have either striped or are slipping on the metal end part of the actual adjuster that connects to the reflector. If not stiped you can dismantle and using epoxy glue the existing gear back on the metal part, if striped you will need new or alternative gears such as these available in this kit for a jaguar x type (the gears are the same as the ones on audis) you only use the gears from the kit, the adjusters in the kit do not fit our cars but I do not know of any alternative gears available seperately.
http://www.ebay.co.uk/itm/Jaguar-X-t...QAAOxyXDhSpd9L
Further thought you could try a 10mm socket or spanner direct on the end of the gear on the metal part rather than using an allen key in the top gear. The 2 gears connect at 45 degrees like this - /\
