Classic Audi » Classifieds section » Parts Wanted » Clutch flex hose
Old 25-10-16, 08:10 PM   #1
Coupe GT
Default Clutch flex hose
I need a new flexi hose for an '85 Coupe GT 2L. Part number 431 721 465. Any ideas? or does anyone know the spec so I can have one made. I'm trying to avoid taking off the old one before I have a new one to install.
1985 Audi Coupe GT 5S, 2L 5CYL.
Coupe GT is offline   Reply With Quote
Old 26-10-16, 11:29 AM   #2
spink
A Mercedes sprinter brake flexi hose can be used,there's a thread on here somewhere about it
Old 26-10-16, 04:34 PM   #3
4v6
Not sure if its a sprinter pipe ( if so will be the same as fitted to VWs Crafters) but I thought it came from a Unimog mecedes military vehicle, Its what i used on mine and it works fine.
The only difference is its about 10mm longer and will need a little thought vis a vis routing it so it dosent chafe, i used a rubber grommet on mine to keep it clear of any obstructioins.
Hurry tho, the parts man I spoke to reckoned theyre going to go obsolete soon.
Old 08-11-16, 04:35 PM   #4
Pete Reeve
Quattro corner has them in stock
Pete Reeve is offline   Reply With Quote
