Classic Audi » Technical » Mech/Tech » Electrical problems » Electric Windows
Old 10-02-09, 01:07 PM   #1
Default Electric Windows
My electric windows have stopped working.
Having stripped back all the disco lighting and peripheral wiring gubbings to something like normality I have found that my electric windows fail to operate. This has really suprised me as the wring harness which connects the switches etc is the only piece of wiring thats not been cut or hacked about. All fuses are in tact at the fuse box.
I checked the wiring diagrams in the Haynes manual and only reconfirmed that these manuals are as useful as a chocolate teapot. There is no wiring diagram for the electric window section.
Also there is an audible lights on warning box been fitted at some stage. Last night it came one and stayed on. All lights were off but the door was open. Closing the door it goes off. Opening the door it comes one...bbbeeeeeeeeepppp!!!. After some wiggiling the ignition key it seems somehow linked. Last night really got to me.
Old 10-02-09, 01:22 PM   #2
vag80
vag80's Avatar
Have you checked you have powwer to the switches,and check you have power from switches to the window regulaters. Is it all windows that don't work
Old 10-02-09, 01:25 PM   #3
Martc
Black Coupe Collector
Martc's Avatar
Couple of things:
Haynes manual you may have to look at a slightly different model to get what you are looking for, its a pain but there were some useful things there....
Couple of thoughts:
The CQ comes with a lights on and stereo audiable warning as standard:
The buzzer is also conencted to the stereo on mine, so if you leave the stereo on, take out the ignition key and you open the door it will buzz, was the stereo also connected up and on?
Are you getting any power to the window switches? There could be another connector further down the chain that has been disconnected which may not be giving you power to the switches.
Are all the earths properly in place?
95 UrS6
87 Coupe Quattro
Old 10-02-09, 01:32 PM   #4
Thanks guys,
no stereo connected at the moment so I can discount that theory.
Both windows are not working and I cant measure any voltage at the switch end. After struggling to get all the dashboard back in last night I am facing the inevitable of getting it all back out again although I may leave it until after BC
Old 10-02-09, 01:56 PM   #5
vag80
vag80's Avatar
If you go to www.kvquattro.com there is wiring diagrams on there i hope this is of help.
ps.i don't know how to put direct links up as im preety crap with computers and just starting to use them
Old 10-02-09, 02:14 PM   #6
Martc
Martc's Avatar
Here is the direct link
http://www.kvquattro.com/audiCoupeWiring.html
Vag80 you just cut and paste the address of the web browser for the page you are at that you want to share.
95 UrS6
87 Coupe Quattro
Old 10-02-09, 02:20 PM   #7
Martc
Martc's Avatar
The other thing to consider is the car had a load of extra things wired in so its probaly not standard, so its very hard to tell what is wrong with the windows without looking at the wiring really, apart from the obvious stuff, like fuses etc etc this would not be easy job to diagnose over the internet.....
95 UrS6
87 Coupe Quattro
Old 10-02-09, 02:32 PM   #8
4v6
Looks like taking a multimeter and test lamp to sundays meet then.......
Haynes has the electric window diagram for the 1985 80/90 saloon on page 394 martyn, will be identical apart from the addition of the extra rear window motors an switches id think.
Just had another thought: Are all the fuesebox rear multiplugs fully pressed home?
Old 10-02-09, 10:36 PM   #9
Spent another couple of hours tonite trying to sort out the windows to no avail. I really need more time and at the moment I just don't have it. So I have the rudimentary electrics to get me to the BC and back. Just hope Jaytee doesn't decide to have a farting fit on the way down, If we turn up green and gagging you'll know why.
Also trial fitted a radio tonite. All works except one rear speaker.
Oh and I have lost the knob for the fan control
Old 10-02-09, 11:11 PM   #10
Puglife
==>PUGSPORT!<==
Puglife's Avatar
Emjay i have a spare heater control knob if needed? any other bits give me a shout i can bring them to cosford on sunday...
I have the audible warning for lights... it gave me a shock first time i opened door with lights on...
As for windows, my passenger side window can be tempremental, sometimes it works but very slowly, other times it wont do a thing. I'm going to look at it this saturday, sometimes the worm drives for the lifting can stick or fail.
MSN/Windows Live Messenger SteveCat General Chat 2 17-10-09 11:00 PM
Electric windows half working MadMax Electrical problems 2 22-04-09 09:24 AM
Electric antenna Ringmaster In-Car entertainment 4 20-05-08 10:52 AM
