Members: 43,035 | Total Threads: 40,085 | Total Posts: 471,031 Currently Active Users: 984 (4 members and 980 guests) Welcome to our newest member, Josephtisse |
Located under the glove compartment. As above, need one of these please as the fan is on constantly.........447 965 571 A
Sometimes numbered on the top as 324. |
Anyone got one?
I'll have a look mate. If I find one, I'll give you a shout
1981 ur quattro CA chassis LHD 1982 ur quattro CA chassis RHD 1986 ur quattro GA chassis - Alpine White 1986 ur quattro GA chassis - Graphite Black
Are you sure that the relay is faulty mate?
It's easy to test it if you're not sure
If the relay is stuck on, then it can only be a false signal or the contacts in the relay have melted together. If so, take the cover off and separate the contacts
It's not actually a relay, just looks like one. Inside is a PCB with various components on.
ETKA List Them As; Control Unit For Coolant Pump & Relay Fan Stage 1 On the S2's it has 324 stamped on top of the case. |
