Classic Audi » Technical » Mech/Tech » Engine » coupe quattro 2.2 KV engine
Old 02-02-09, 08:14 AM   #1
Derek
Default coupe quattro 2.2 KV engine
anyone know the correct ignition timing for the KV engine the manual says 9 deg btdc on unleaded 18deg btdc with leaded it runs just about the same any ideas
Derek
Derek is offline   Reply With Quote
Old 02-02-09, 08:40 AM   #2
4v6
On the KV, Vacuum hose connected, 17 to 19 Deg BTDC @ 800RPM iirc.
Old 02-02-09, 08:43 AM   #3
Derek
Default 2.2kv
champion
Old 02-02-09, 10:03 AM   #4
It's good that there is so much manuals that ppls don't need even think about what they are doing
I learned how to adjust my 3A's ignition just by feel, of course, settings for electronic ignition is different but principle is the same.
Old 02-02-09, 10:27 AM   #5
4v6
Yeah i long ago got the knack of learning to set carbs up and ignition just by feel, mind you thats what happens when every day is a test day on your own car.
I would often pull over at the side of the road and add a little more initial timing or tweak the carb to make it idle nicer.
I got quite adept at stripping bosch distributors and tightening the advance springs a little or loosening them to alter advance characteristics, its quite useful stuff to be able to adjust those things and get rid of a pinking problem.
Coxy's Variant engine was a blast from the past in that respect- just looked too simple as tho itd not work almost, especially when compared to todays stuff.
I still prefer injection tho, theres so much you can change to get it right for each individual engine.
All good stuff.
WR UR quattro engine + components Puglife Parts For Sale 5 03-07-17 05:36 AM
20v Coupe Quattro engine audi_kid Parts For Sale 0 13-08-09 09:09 PM
kv engine and other quattro stuff audicoupeparts Parts For Sale 1 11-06-09 09:32 AM
1B Engine (same as MB ur quattro) steveb Engine 5 22-04-09 10:06 PM
UR quattro ecu (for wr engine) for sale. Jenks Parts For Sale 1 15-02-09 03:14 PM
