Classic Audi » Technical » Mech/Tech » Electrical problems » Flat Battery
Old 01-07-15, 05:56 AM   #1
gazza1971
gazza1971's Avatar
Default Flat Battery
Went to use the car Saturday the battery was flat jump leads it started no problem used it all day no problems .The wife went to open it last night the remote locking wouldn't work opened with key alarm went off only one door opened I came home from work its the same battery is flat even with jump leads on it does nothing .Going to replace the battery today will this be the cure guys seems like its got no power at all even with jump leads it would not turn over no remote unlock central locking aint working went to start it the factory alarm is going of the indicators flashing like its immobilised its a 2.0 16v coupe .
1993 B4 Coupe 16v
gazza1971 is offline   Reply With Quote
Old 01-07-15, 06:41 AM   #2
Best case(read cheepest!) scenario is that it's the battery. If the battery is really goosed, don't expect to throw a cheep set of jump leads at it and expect it to fire up instantly?
If you have a drain on the battery (ie fault with vehicle electrics) this would need checking with a meter.
Charging fault would mean it might charge sufficiently to run the car but not to start it......best case here would be earth strap, and this would also cause poor starting/cranking.
If you attached jump leads to battery and it didn't want to turn over and then you removed the NEGATIVE jump lead from the battery negative and attached it to the metalwork of the engine.......and it started, then doing it this way would be bypassing the engine earth strap and suggest there may be a problem here?
You say you're going to replace the battery, get it tested first as the money you'll save not buying one might need to go towards an alternator!!(worst case scenario)
Hopefully just a goosed battery though.
Let us know.
Old 01-07-15, 08:07 AM   #3
gazza1971
gazza1971's Avatar
Thanks for the reply the battery looks old euro car parts £32 for a new one 3 year warranty .I will let you know later after work when I have fitted it thanks again .
1993 B4 Coupe 16v
Old 01-07-15, 09:00 AM   #4
Personally I'd avoid their Lion ones.......
Old 01-07-15, 09:06 AM   #5
leggy
Ditto that John
Old 01-07-15, 12:20 PM   #6
gazza1971
gazza1971's Avatar
Bought a Bosch one hopefully will sort it out when I finish work later
1993 B4 Coupe 16v
Old 01-07-15, 05:51 PM   #7
gazza1971
gazza1971's Avatar
Fitted the new battery central locking not working alarm going off when you open with the key and will not turn over as if its immobilised any ideas ?
1993 B4 Coupe 16v
Old 01-07-15, 06:14 PM   #8
Maybe alarm/immobiliser out of sync.
I'll bet there's a thread somewhere on this....
Maybe try putting the driver's window down, then lock the car and reach in, put key in ign and see if it'll start then.
My car doesn't have factory immobiliser so not overly familiar with B4 setup.
Old 01-07-15, 06:24 PM   #9
gazza1971
gazza1971's Avatar
Googled it left the battery disconnected for 30 mins and bingo all sorted phew panic over.
1993 B4 Coupe 16v
Old 01-07-15, 06:24 PM   #10
http://www.classic-audi.co.uk/forum/...ht=immobiliser
Above thread was what I had in my head regards previous topics........
