Classic Audi » Technical » Mech/Tech » Engine » petrol
Old 20-01-09, 10:35 PM   #1
irish80sport
irish80sport's Avatar
Default petrol
just after taking possesion of my 1985 1.8 sport. do i need to do anything to run it on unleaded maybe i need an additive or somthing, im a bit green ehen it comes to these things? also there is a note saying to bleed a valve when topping up coolant, whats that all about? any help would be much appreciated.
irish80sport is offline   Reply With Quote
Old 20-01-09, 10:43 PM   #2
I run my 5 pot coupe on high octane unleaded with no real problems. admittedly I only do limited mileage but is seems ok. If in doubt I would maybe use an additive plus high octane.
I'm sure one of our more knowledgable members may be able to help more.
Old 20-01-09, 11:12 PM   #3
It'll run just fine on 95RON, maybe a bit more spritely with 98RON...
And no knowledge on the bleed screw, unless there's something around the heater matrix to vent out airpockets?
Old 20-01-09, 11:16 PM   #4
I've used 95ron normal pump unleaded in my Sport since I've had it and no problems at all and that's done 8000 mile since I've had it.
Old 20-01-09, 11:21 PM   #5
4v6
All audis since 1974 have been capable of running on unleaded iirc.
Old 20-01-09, 11:23 PM   #6
Could be about right cos all VW's since 1972 have been able to run on unleaded.
Old 20-01-09, 11:29 PM   #7
Put V Power in it and get better performance, and fuel economy, which offsets the extra cost.
Old 20-01-09, 11:30 PM   #8
I run both mb's on 95 ron and they are happy .........if i stick higher in they complain beastie requires diesel
Old 20-01-09, 11:38 PM   #9
how much mpg do you get in your 100?
Old 20-01-09, 11:40 PM   #10
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
I run mine on 97, seems to go a bit better and seems happy. 95 seems fine as well, 99 from Tesco is a no no, my car tends to cough and splutter!
On the fuel filler cap it says 98, but then 97 is its replacement. Surely if it's set up for 98 originally then now its been retarded to run 95 unleaded at some point? Still a mystery as to whether mine's been adjusted to run 95...
petrol tank andy e Parts Wanted 6 19-02-10 12:09 AM
Petrol deteriorating Audi Derek General Chat 7 24-12-09 05:37 PM
petrol cap quattro eltee Engine 1 30-10-09 02:34 PM
Petrol now less than a £1.00! Coxy General Chat 9 15-10-08 09:13 PM
