Classic Audi » Technical » Mech/Tech » Electrical problems » ABK volt meter
Old 16-02-15, 08:35 PM   #1
hunker7
hunker7's Avatar
Send a message via Skype™ to hunker7
Default ABK volt meter
Hi guys. My brother bought a very nice A80 the other week to replace his rusty A80 which is also ABK
His old one came with the additional gauges (oil pressure, oil temperature and volt meter), and he'd like them in his new one. I sort of have found out where the oil sensors live, and they would be straight swap I assume? But can't find any info on the volt meter? How does that connect and where?
Some pictures:
Not a spot of rust on it, and suspension is so quite.
'93 Audi 100 Avant - R.I.P
'92 Audi UrS4 Avant - SOLD
'93 Audi UrS4 Avant
'05 Audi A8 D3 4.2 V8 - LPG
hunker7 is offline   Reply With Quote
Old 16-02-15, 08:54 PM   #2
Please, not another "I don't have a clue about electrics, but I want to fix something" thread Oil gauges aren't powered by power of magic, they aren't mechanical either - they are powered with electricity. That's exactly what voltmeter measures.
Old 16-02-15, 09:00 PM   #3
hunker7
hunker7's Avatar
No shit Sherlock. It must be connected somewhere just can't find wiring diagram for it.
'93 Audi UrS4 Avant
Old 16-02-15, 09:18 PM   #4
martinws
You will need to pick up an oil pressure and temp sensor and wire them back into the cabin and into the gauges. The volt meter I think just takes a 12v switched feed straight from behind the dash. There might be a separate loom available for these from a car being broken but I don't know. I fitted the gauges with homemade loom joining onto he RS2 loom I put I'm my typ85.
Old 16-02-15, 09:23 PM   #5
hunker7
hunker7's Avatar
Doesn't sound that bad. The "new" car should have space for the sensors etc. right?
'93 Audi UrS4 Avant
Old 16-02-15, 09:59 PM   #6
Mellis46
Aero Advocate
Mellis46's Avatar
There is a white plug shaped like a Tetris piece buried under the forward section centre floor console (below the dash in effect) that has the wires in it for the illumination and voltmeter in the additional gauge set, as set out above the oil temp and pressure gauges have separate wires connecting to respective senders in the engine bay.
I am more used to the 5 cyl (KV) set up of a 90 B3 but i have met the ABK before, both senders live quite close to each other iirc to the right of the engine on / near the oil filter housing?
Old 16-02-15, 10:06 PM   #7
hunker7
hunker7's Avatar
Yea, they all live in the same place, senders and sensors.
'93 Audi UrS4 Avant
Old 16-02-15, 10:25 PM   #8
Mellis46
Aero Advocate
Mellis46's Avatar
There you go then. All you need to do to make the physical space for the gauges and the replacement console is remove the new car's pull out ashtray. Don't forget the little finishing strip that tidies up the dashboard lower edge
Old 16-02-15, 10:28 PM   #9
hunker7
hunker7's Avatar
I guess it'll take some fiddling but will be worth it. And dash is coming out too as matrix needs swapping, so that will make things somehow easier.
'93 Audi UrS4 Avant
Old 16-02-15, 10:29 PM   #10
Mellis46
Aero Advocate
Mellis46's Avatar
BTDT, good luck!
