Classic Audi » Classifieds section » Parts Wanted » Type 85 Coupe quattro steering rack asap
Old 11-02-15, 01:27 PM   #1
20vcqdriver
20vcqdriver's Avatar
Default Type 85 Coupe quattro steering rack asap
Has anyone got a serviceable type 85 power steering rack. Mine is on its way out despite being overhauled 10 years ago and only done 30K since... Needed asap and looking at it half the engine is going to have to be dismantled to get it out...... Was easy last time as I had an empty engine bay..... All help appreciated
Old 11-02-15, 04:26 PM   #2
willow
Hi I have one in the republic of Ireland.
any good to you?
Actually, its not from a quattro, so probably no good?
willow is offline   Reply With Quote
Old 11-02-15, 04:32 PM   #3
20vcqdriver
All type 85 power racks are the same... if memory serves me correctly.
This issue started to show itself last year and assumed the bushes were to blame..... but no you can grab the moving part of the rack and rotate it 30 degrees from way tothe other which in turn alters the steering very slightly. Prefer not to drive the car in anger in case it goes altogether......
Just a thought but is there any adjustment on these Be great if all it needs is some shims or adjustment
Old 11-02-15, 05:49 PM   #4
M4rkp
M4rkp's Avatar
All type 85 racks are not the same - granted, there is very little difference in them for instance my WR Quattro has part number 857 my coupe has part number 811 - they look identical - but 811 has more teeth on the rod giving it a better (smaller )turning circle.
I would certainly be wary of your rack as it sounds like the pinion cog which drives the shaft is worn! -
I have just had all sorts of steering woes lately, - I've learnt a lot from from this, there are lots of companies out there that refurbish racks and generally are quite free with their information and advice -
Unfortunately there is no adjustment capabilities on the racks - once they have worn they are scrap.
Mark
M4rkp is offline   Reply With Quote
Old 12-02-15, 12:11 AM   #5
20vcqdriver
Looking at ETKA it seems I need a rack with part number 812 422 065EX for RHD cars. Hope this helps
Old 16-02-15, 08:54 AM   #6
jmm
You can always put steering rack from b3 or b4. The best option would be one from 2.8 v6 with servotronic.
jmm is offline   Reply With Quote
Old 16-02-15, 09:33 AM   #7
audicoupeparts
I've a wr ur rack and a 2.8 cq rack if any use
Old 16-02-15, 10:45 AM   #8
JMLAudi
JMLAudi's Avatar
Smile
HI
I got a rack from a 2.6 Audi quattro Avant B4
Where are you??
located in Shipley/Bradford or knaresbough
cheers
john
Old 16-02-15, 12:39 PM   #9
20vcqdriver
I'll be going nowhere near a servotronic rack...
They were heavily critised and the later S2's reverted back to a normal rack after complaints. Steering on the series 2's is one of the best setups Audi have had, so stick with it.... cheers
Old 16-02-15, 12:40 PM   #10
20vcqdriver
Been offered a GT rack that appears in good condition, let you know how it goes
Thanks for help from everyone..
