Classic Audi » Community » General Chat » Best clean and strip disc?
Old 08-01-15, 11:13 PM   #1
Default Best clean and strip disc?
Have a 115mm 4.5" angle grinder and need discs,to strip paint off car body.Which are,the best to use?
Thanks.
KARL.
Old 08-01-15, 11:19 PM   #2
styler
styler's Avatar
if its just for small repairs use a flap disc..
paint stripper and a knotted wire brush for bigger jobs..
that any help?
CRASH VALLEY CUSTOMS
get 'er done...
Old 08-01-15, 11:47 PM   #3
S3ilver
Thanks.
Search for "Poly Strip Disc" on google. Brilliant if you are just wanting to take paint off and light rust but will not take off metal.
S3ilver is offline   Reply With Quote
Old 09-01-15, 05:56 PM   #4
swb quattro
Paint stripper what kind of paint stripper you using i have tried a few types and they will not shift the paint on my ur it's lifting the lacquer but not the base coats
Going to get poly strip discs aswell but iam going to get 3m one's as used them before and there great although a bit more expensive
swb quattro is offline   Reply With Quote
Old 09-01-15, 08:33 PM   #5
moonwatcher
moonwatcher's Avatar
Flap discs, I get mine from frost.co.uk
Coupe Quattro 1985
Old 09-01-15, 08:41 PM   #6
styler
styler's Avatar
did you scuff the paint with rough sand paper before applying the stripper?
get 'er done...
Old 09-01-15, 08:52 PM   #7
Thumbs up Thanks lads.
Thinking of stripping the whole shell,back to metal?
How long would the 3M disks last and how many,do you think I'd need?Also how many hours would it take,to strip whole car?
Any experience or help,would be greatful.
What are your thoughts on,universal dust extractor(angle grinder)?
Thanks.
KARL.
Old 09-01-15, 09:03 PM   #8
styler
styler's Avatar
if you use a flap disc you will warp and mark the metal... i doubt it needs bringing back to bare metal everywhere!!! just do the areas where repairs are needed and only the bit you intend to do start to finish at any one time.. .. you hear talk of bare metal resprays .. that needs to be done in the correct environment cause every second the metal is bare it vulnerable to rust, itll look fine and you apply paint... then a couple of months down the line you get spiders under the paint .. if you really want to do that send it for chemical dipping... at least it will be treated with a primer as quick as possible, take it back and do your repairs.. then send it for painting... hope that makes sense... im not the best at verbalizing...
get 'er done...
Old 09-01-15, 09:12 PM   #9
Default New to all this.
No that makes sense and I'll take it on board.
Maybe I won''t go to,bare metal?Only to,repair areas.
What disc would I need to strip,only top layer of paint off?Or would I,need a disc?
Thanks.
I will have to,do some research.
KARL.
Old 09-01-15, 09:16 PM   #10
styler
styler's Avatar
i use a knotted wire brush attachment on the small angle grinder on repair areas, or a flap disc..
flap disc
knotted wire wheel
get 'er done...
