Classic Audi » Technical » Mech/Tech » Electrical problems » dodgy battery or alternator? 85' cq
Old 28-05-14, 07:22 PM   #1
andya
andya's Avatar
Default dodgy battery or alternator? 85' cq
Used my car saturday. Went to go out last night and the battery was as flat as a pancake. Charged it overnight. It started first time. Used a voltmeter - 12v off, 13 volt on, and when I rev it, the volts hover no more than 13v. Am I right in thinking the volts should increase with higher rpm? And if so, could it be a dodgy alternator?
Any thoughts would be appreciated.
Cheers
Andy
1985 Coupe Quattro
1986 Coupe 1.8 weber carb
1987 Coupe 2.2 GT
Old 28-05-14, 07:35 PM   #2
It should be closer to 14 volts when running but the revs shouldn't matter.
Are you handy with a meter? Volts drop test under load wouldn't be a bad idea.
Old 28-05-14, 07:44 PM   #3
Default Bosch 75/90 A
Engine running at 3000 rpm,all electrics off and volts should be between 13.5-14.5.
If not,could be voltage regulator?
KARL.
Old 28-05-14, 08:15 PM   #4
andya
andya's Avatar
Cheers for those tips everyone. Will be tomorrow evening now before I can have another go. Perhaps the persistent rain may have gone by then!!
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 28-05-14, 10:32 PM   #5
As Karl says, volts should be about 14.5V with the engine running, it'll only drop with electrical load, but the voltage regulator should prevent the volts changing as the revs change.
My guess is a failing alternator output or an earthing problem.
Old 30-05-14, 08:41 PM   #6
andya
andya's Avatar
Well a bit odd. Charged the battery tuesday night and all is fine. Was beginning to think maybe I had left the radio on on the night the battery went flat. But just come back from a nights drive, and a few things I noticed. The volts display dropped to below 12v with the lights on - is that normal, never noticed that before, as soon as I put the indicators on, the volts drop down once again by 1 notch. Off they go back, switch my lights off, and its back up to 12v. Am I being paranoid? Ive dug out a spare alternator just in case
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 30-05-14, 08:49 PM   #7
Is the battery charging light faintly illuminating when the lights are on and you are indicating....? If it is, its an earthing issue, quite possibly off the starter motor area....
Old 30-05-14, 08:52 PM   #8
andya
andya's Avatar
Yes when the indicators are on, I can see the battery charging light faintly flickering
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 30-05-14, 09:03 PM   #9
Right, its an earthing issue... First job, check/clean all the earthing points for the heavy stuff... So think starter, alternator, engine gubbins etc....
Old 30-05-14, 09:31 PM   #10
andya
andya's Avatar
Right, will get onto that tomorrow morning.
Cheers
Andy
1985 Coupe Quattro
1987 Coupe 2.2 GT
