Classic Audi » Technical » Mech/Tech » Electrical problems » Drivers window won't go up or down..
Old 12-03-14, 02:00 PM   #1
Vince70
Vince70's Avatar
Default Drivers window won't go up or down..
I wonder if someone could give me some advice my drivers window on my Audi Cabriolet has decided only to work once in awhile..
I don't think it's the switch as when I use the switch on the centre console the other 3 windows go up and down and the drivers window still doesn't work and it also doesn't work when using the switch on the drivers door panel.
I just wondered if it could be a relay but the thing is why wouldn't it affect the other 3 windows also I've had a quick look at the relay and it's numbered 343 and not the usual 363 or 367 so could I use the later relay if it was the relay
Also when I press the the electric window button I can hear a click coming from the relay
Vince70 is offline   Reply With Quote
Old 12-03-14, 04:04 PM   #2
Tun
Tun's Avatar
It will be the relay, I don't know why it only affects the drivers window but it does. It's quite often dry solder and can fixed or so I have been told.
1988 MB quattro
2012 S4 Avant
