Classic Audi » Technical » Mech/Tech » Electrical problems » Central Locking Trouble
Old 17-08-13, 12:30 PM   #1
Default Central Locking Trouble
any idea what i need to correct the intermittent working of the central locking on the audi 90?
the driver's side rear door button goes down sometimes and the boot has stopped locking with the central locking all together now. rubbish! do you think that the central locking solenoid actuators are gubbed in these two areas?
thanks,
craig
Old 17-08-13, 12:42 PM   #2
shaun5
shaun5's Avatar
thanks,
craig
For the boot, are you sure someone hasn't unlocked it and left it in the wrong position? meaning it wont open with the central locking!!!!
Old 17-08-13, 12:46 PM   #3
not if it's the same routine as i had on the audi 80. the central locking for the boot only happens when you have the key at the horizontal position, if i'm correct. it used to work and then just gave up the ghost one day. you can hear a whirring noise inside the boot for some time after locking the car but the boot won't lock itself any longer and i have to do it manually with the key at the vertical position....
thankfully, not everything in life is as troublesome as a classic audi...!!
Old 17-08-13, 12:52 PM   #4
Ben
Normally, the pump should run for a few seconds until all the locks have actuated, if an actuator doesn't work when others do then it could be stuck or it's pipe is crushed stopping the flow, if the pump continues to run for up to 30 seconds then a pipe is off somewhere.
1992 80 quattro 20vt
Old 17-08-13, 12:52 PM   #5
Andy b1 (WR)
Andy b1 (WR)'s Avatar
Don't you just love em! "I love it to bits" think that's what i keep saying too myself.
Classic Audi's eh!
Andy b1 (WR) is offline   Reply With Quote
Old 17-08-13, 01:05 PM   #6
shaun5
shaun5's Avatar
2nd that sounds like a vacuum pipe is off
Old 17-08-13, 01:08 PM   #7
Hanuman
Hanuman's Avatar
It's all vacuum, isn't it?
Does it sound at all like the pump is running too long?
If some of the locks are working normally, then at least the sytem is generally working, so now it's a case of checking individual bits.
One thing is the actuators have a rubber diaphragm, which gets brittle, cracks, leaks- result. no movement.
Pipes bent.
But if everything has been working, then I'd think about the actuators.
Old 17-08-13, 01:42 PM   #8
lefthooker
Sounds like an advert slogan. The complete opposite to 'If only everything in life was as reliable as a Volkswagen'.
Old 17-08-13, 03:26 PM   #9
mrpat
mrpat's Avatar
Send a message via MSN to mrpat
Sound like a leaky locking solenoid if the pump is running too long.
80 quattro 20vt
Octavia VRS (the daily)
'88 Mini turbo (will see the road again.....one day)
mrpat is offline   Reply With Quote
Old 17-08-13, 03:28 PM   #10
mrpat
mrpat's Avatar
Peugeot or Renault should take that up as there new slogan.
80 quattro 20vt
