Members: 43,039 | Total Threads: 40,083 | Total Posts: 471,018 Currently Active Users: 638 (0 members and 638 guests) Welcome to our newest member, Danielordem |
Not been on for a while, as my Cab has been in regular use, without any issues
Came to use it for a couple of days away with the wife, and gear selector wouldn't move from Park!! Had to move all bags etc into the A4 The auto check also didn't clear the brake light test, so I am assuming its related to that. Could it be the brake switch?? Or more involved(ie expensive)? How big a job to fit new switch?
1999 2.8 Cab Final Edition Java Green Black Recaros -Sublime 2010 TTS Roadster Imola Yellow - wife's toy 2015 A4 Allroad 3.0tdi - Silver 1999 Mercedes SL320 - we all make mistakes..... Sold 2014 SQ5 sepang blue 07 3.0Tdi A4 Avant Black Edition Mauritius Blue - longest I have EVER owned a car 1996 Mk3 Golf Anniversary black magic pearl 01 Hi-Lux Pick Up - worth it's weight in gold! - cashed in before it started costing a fortune - replaced with a trailer for the tip!!! |
Ragtop Collector
Run a check and see what fault codes are coming up.
"Earl" 1998 2.8 V6 Cabriolet "The Duke" 1997 2.6 V6 Cabriolet (Sold....sadly) Project "Best of Both Worlds" 1995 S2 Quattro Cabriolet
Thanks Andy,
Unfortunately, I don't have a tester, and obviously car is now stuck on my drive, so can't get it to a garage (being on Anglesey, there aren't many about who are interested in proper cars)
Ragtop Collector
Ok try disconnecting the battery overnight to try and reset the ECU. This may clear the fault that's been thrown up thats locked out the box. Is the car on the flat or on a hill and parked on the gearbox rather than the handbrake?
Isn't there a switch which opens when the brake pedal is depressed which then allows you to move from P to R, N or D?
Sounds like this switch is the problem. |
Thanks Guys,
Will try the battery when we get home on Tuesday. I am hoping it's no more than the switch
Car is on a very slight slope, and parked on the gearbox. Although I have had the handbrake on to lower the roof( and then raise again once I realised we wouldnt be enjoying an open top drive along the A55)
Ragtop Collector
Its possible the box has simply locked against the park, try pushing the car up hill and seeing if it will then release out of park.
#9 | |
Not a permanent fix obviously as it'll jam again as soon as it's put back into park but at least it would get the car moving if you need it shifted? John. |
Classic Audi Pervert!
Can you hear the switch click when you press down the brake pedal? If not, then I agree with Coxy - could be a faulty switch.
