Classic Audi » Technical » Mech/Tech » Engine » exhaust question
Old 12-11-08, 03:17 PM   #1
Scarlet
Scarlet's Avatar
Default exhaust question
When i bought the type 44 the exhaust was a scafolding pole welded on to a back box, since then i have had a custom stainless steel exhaust made for it, the manifold is a dialynx one and the exhuast is a straight through system.
Could this be strangling the power for the engine? the car does hold back sometimes and i was wondering if its the exhaust thats at fault.
Dont want to go and get another exhaust made for it unless i really have to as the one thats on it sounds good
Was just a random thought that it might not be doing the engine any favours
t44 2.2 turbo quattro
B4 80 Avant
t44 100 2.0 saloon
Quattro Nation
Scarlet is offline   Reply With Quote
Old 12-11-08, 08:43 PM   #2
I would have thought that a straight through would improve the gas flow and make the engine breathe a bit better?
When did you last change your air filter?
Old 13-11-08, 05:06 AM   #3
spaarky
spaarky's Avatar
I'm with quattrokid - surely if you've got custom exhaust pipework & manifold + a straight thru silencer, you've got about as much exhaust breathing as the engine can handle unless you go up to a larger bore system ? i.e. on the list of your engine's limitations, the exhaust system should now be last on the list, not first. Unless there's summat else bothering you about it, that I'm missing ? Is your custom exhaust system made in tubing smaller than the stock bore ? This is the only way that I can see your exhaust system might be 'strangling' the motor's breathing & power
spaarky is offline   Reply With Quote
Old 13-11-08, 02:27 PM   #4
joe90
Do you have a cat in the system? this could be the problem.
Bryan
Old 13-11-08, 02:46 PM   #5
4v6
Bryan
Ive just done a set of heads for a chap who strapped them on his converted car which promptly made less power and torque than it should.
It was abysmal.
After some conversations with him i found out he was using a cat converter he'd had squirrelled away in his shed for years.
Turns out the cats too small (2.0litre needs a 3.0litre version) and was absolutely killing power and torque. Replaced it with a de-cat pipe and it flys according to him...
Ive yet to find out if the cats damaged at all but i suspect its got some internal problems as well as being too small.
If you can get the cat off you should be able to see through it with a torch at one end but itll be very directional ie, youll have to be looking straight down the sections to see out the other side.
Could be a cat problem but id still be looking elsewhere first.
Do the basics, plugs and leads, compression test, dizzy cap and rotor, fuel filter and fuel pressures, air filter, ignition timing etc.
Old 13-11-08, 03:52 PM   #6
Scarlet
Scarlet's Avatar
Thanks you have all said the same as i was originally thinking, there is no cat on the car its just a straight through exhaust (2.5" if i remember correctly?) .
Got a funny feeling it has something to do with a sensor somewhere just a case of going through everything till i find it, was going to changed plugs, leads, cap etc anyhow.
When i got the exhaust done i thought if its straight through it would help get the gasses out quicker and the guy who done it checked it would be fine before making it up.
Sometimes its a rocket other times it holds back!
B4 80 Avant
t44 100 2.0 saloon
Quattro Nation
Old 13-11-08, 04:04 PM   #7
Nowt wrong with a streight through system, I had an OEM system on the quattro, changed that for a single box Miltek, still to quite, changed that for a custom stainless 3" system, sounded rather good but still not quite right, now we have a completly streight throw system with a dummy box on the rear 12" x 9" x 3" which is the same size as the Group 4 car's had, except this has no baffles what so ever. Quite liverble with ever though some on here thinks she's a bit load
Old 13-11-08, 05:29 PM   #8
crisarc
Default t44 exhaust
Cannot see it being your system, if the power is on/ off , more likely filter / plugs , or the myriad of sensors on the car, best to do the basic checks first, i have had t44s for years and even ambiant temp can knock the performance!, a 2.5 system is more than enough for a cooking 10v t44, jet wash the intercooler matrix, and clean the inlet manifold temp sensor, check plugs , rotor etc,
good luck
chris
Old 13-11-08, 05:58 PM   #9
100turbo c
100turbo c's Avatar
Send a message via AIM to 100turbo c
hi my car was holding back just the same, on the plug leads there is metal shrouds, they are there for interference reasons, i took them off and completly different car no holding bck and a lot smoother try this ... i thought it was fueling but definetly was not
100turbo c is offline   Reply With Quote
Old 13-11-08, 10:09 PM   #10
Straight exhaust is good, if u have problems with ears and if u have turbo engine - there should be both reasons
About cat - interesting, how much does cost new cat?
question ? Micky General Chat 17 06-12-09 09:39 PM
10v Radiator question djb1607 Engine 7 31-07-09 05:31 PM
Question ? Micky General Chat 9 24-12-08 10:01 PM
