Members: 19,823 | Total Threads: 40,093 | Total Posts: 471,115 Currently Active Users: 2003 (0 members and 2003 guests) Welcome to our newest member, BuddyInons |
I want a dump valve for the Type 44, its the MC engine 10 valve. (2.2 turbo quattro)
I want one that makes the noise you get off the newer ones (the woosh of air sound lol) can anyone give me a link or contact details of anywhere i can get one? |
be very careful when fitting a dump valve. can cause more problems then they are worth.not sure about audis but some systems are sealed breathing .and dump valves cause erratic idling.get advice before you do it.
The car already has a dump valve as standard fitted to it
not sure ,are you on about the wast gate?
No the waste gate is fine, however i was told the dump valve would need replacing soon.
Seemingly these were bad for going on this engine or something, but the guy hasnt ever fitted an after market dump valve to this engine so couldnt advise on which ones to buy. Im going to be fitting the uprated waste gate spring but the car is down on power becasue of the dump valve so want that sorted first |
He's confusing dump valve with blow-off valve
![]() Dump is better, without that stupid "psh-psh" sound all thime Ok, some kids like them - "I'm the real need for speed man" ![]() P.S. I heared that big pressure difference can reduce life of turbo - in case of blow-off. |
i must admit i have never seen a dump valve on a older audi . what does the book say if you have one?
#8 | |
I think most VAG turbo applications from the factory run a re-circ system nwhich dumps the excess boost back into the system! |
#9 | |
Summat like this: http://www.forgemotorsport.co.uk/con...oduct=FMCL007P Not sure if that particular one will work on your engine though, they also sell uprated waste gate actuators!!! |
Dump valve connects exhaust side of turbo to intake side of turbo, while blow-off connects exhaust side with atmosphere, making this sound
| B3 80 Sport SE 8 Valve | David Small | Cars For Sale | 0 | 04-09-09 12:13 PM |
| looking for 1 exhaust valve | sam | Engine | 2 | 15-05-09 07:33 AM |
| Dropping a valve @ 20k!? | Gaz | Engine | 5 | 10-01-09 11:05 PM |
| How not to do a valve job | joe90 | General Chat | 4 | 03-12-08 06:25 PM |
