Classic Audi » Technical » Mech/Tech » Electrical problems » Disabling ABS?
Old 30-08-12, 09:19 PM   #1
Jolfa
Default Disabling ABS?
My new 90q has got the ABS button but it doesn't appear to work, it switches off fine when the diff is locked, but not on the switch. Is it likely to be a switch fault?
Can I just permanently disable it by cutting a wire or something?
Jolfa is offline   Reply With Quote
Old 30-08-12, 09:58 PM   #2
Stuart16v
Don't quote me on this but when I take the fuse out on my 95 Coupe it runs just fine and the light stays off, try that maybe.
Stuart16v is offline   Reply With Quote
Old 30-08-12, 10:12 PM   #3
sam
pull the fuse and the bulb from the clocks... had no ill effects on my 90q done this way and brakes get abused...
Old 30-08-12, 10:17 PM   #4
Jolfa
Well that's that then, cheers guys!
Old 30-08-12, 11:24 PM   #5
Hanuman
Hanuman's Avatar
As a very quick response, (late night guessing) if the ABS is otherwise fully functioning, I'd say there is a switch fault, or someone may have simply bypassed the switch to overcome a witch fault.
The problem that you have is that the abs should be either fully operational, or the system completely missing for the purposes of the MOT (if I understand the requirements). So whatever you do, you should make the the effort to do it in such a way as to make it easily reversed if required.
I'll dig through my various antes later after another think.
Old 30-08-12, 11:29 PM   #6
Jolfa
The problem I've got is that the ABS kicks in nearly every time I brake, even gentle braking at low speeds.
I'm sure I could address the problem and fix it, but I don't like ABS anyway
Old 30-08-12, 11:46 PM   #7
Hanuman
Hanuman's Avatar
That sounds like sensor issues. Often, the system just needs a good clean up of the sensors at the hubs.
There is a relay which enables the system assuming that a number of parameters are met.
-The supply line must be above a minimum voltage.
Recently, when I lost the output off my alternator, system volts dropped below 9 volts before the ABS switched off.
-it compares signals from all sensors. 4 wheels and later systems with the accelerometer. At standstill, it can only verify that the sensors are providing some input. It isn't until the car starts moving that it can compare the signals from all the wheel sensors. Often, bad sensors, dirty, or damaged drive shaft toothed rings will result in a system fault after moving away. I recall a distance of about 60ft(?)
-switches. Diff lock and the ABS on/off. The on/off switch resets each time the ignition is turned off. Ie. it should default to on every time.
The idea of all this is to have a fail safe. The light being part of that.
Old 31-08-12, 05:53 AM   #8
Agree about sensors. Sounds like rusty tooth rings or sensors themselves too far from the rings. About the switch - it's likely that the contacts inside are dirty, I had the same problem with my A90q after it spent two years in a garage, I was too lazy to take it apart and instead quickly pushed it for a couple of minutes. Now it usually works, in worse case on second or third attempt.
P.S. Last winter tried ABS in snow, having the car equipped with very old all season tyres with 3-4mm thread - to get the ABS kick in, the principle was as usual - I had to brake harder than I wished Of course, there is some situations when ABS is not good, for these there's that switch
Old 31-08-12, 06:58 AM   #9
Hanuman
Hanuman's Avatar
Toothed rings.
The ABS sensors are looking at toothed portion of the drive shaft. As the shaft rotates, the ecu sees a pulse waveform from each of the wheel sensors. It compares these initially from standing to moving, to see that all wheels are turning. If the signals are comparable, all sensors are good.
It then continues to monitor these waiting to see when one signal is changing by more than all the others. Locked wheel. It then does its thing on that line. Release left or right front, or rear (one line, so both released)
If under braking, the ABS is kicking in early, then it must be seeing a bad signal. The signal is not so bad that it fails the comparator. But bad enough to indicate a locked/locking wheel.
rusted sensor rings on the drive shafts are common. Most common on the front. Some suggest that front left is worse than righ. My ur demonstrated many of the same issues, and it is surprising how bad the rings can be before the system can no longer cope. Damp increases the problems.
The Sensors are easily removed and reseated on the later cars. Wipe them off. Have a look down the hole with a small torch, and you should be able to pull out any debris in there.
The switch in the dash is a simple illuminated switch, common to yours, used on my V8 also.
Old 31-08-12, 07:00 AM   #10
rtz62
rtz62's Avatar
From an Objective point of view, don't disable the ABS; if you have an accident and there is any inspection of your car and it shows it was disabled / inoperative, you'll have no claim.
However, pressing the button to disable a properly-functioning abs system is totally different....!
