Classic Audi » Technical » Mech/Tech » Interior » After market central locking
Old 03-01-12, 11:49 AM   #1
Tun
Tun's Avatar
Question After market central locking
My 90 quattro does not have central locking. I have seen a couple of kits on ebay around the £20 mark to retro fit to the car. Has anyone had any experience with these kits good or bad or should I be looking at spending more and going for car alarm with central locking?
Old 03-01-12, 01:00 PM   #2
stuartmmcfc
years ago i fitted one to my quattro with no problems (it wasn't actually a central locking as a remote actuator which worked the central locking via a rod attached too the central locking pump- but the principals the same!).
However, if you can afford it surely a full alarm would be a better option?
Old 03-01-12, 01:31 PM   #3
Phil Payne
Banned
Even if you go with the alarm you'll probably need to change the actuators.
Maplins do a good five-wire solenoid actuator - £9.99 per door.
Old 03-01-12, 10:21 PM   #4
A_N_Other
Converted mine to remote central locking, with alarm, immobiliser and remote start (not used it this year...)
Easy to fit, all I did was replace the drivers switch with another vacumn solenoid (from a VW Jetta I think) I had lying around and stitch the locking unit into the wires and it all seemed to work.
Only problem is that I went for the one with fake VAG 3 button flip keys: the hinge and key connection is a bit loose now after a year of every day driving....
And the instructions are in Chi-nglish so a bit of a headache.
Otherwise spot on.
A_N_Other is offline   Reply With Quote
