Classic Audi » Classifieds section » Parts Wanted » Rear callipers for s2
Old 22-12-11, 11:52 PM   #1
nimz
nimz's Avatar
Default Rear callipers for s2
Hi guys, anyone near m1 j28 got some s2 rear callipers? Could do with them ASAP. Thanks in advance
I am here: http://maps.google.com/maps?ll=53.107346,-1.332802
Nimz - 2.3l 10v 5cylinder pearlescent white 1993 cabriolet
nimz is offline   Reply With Quote
Old 26-12-11, 11:49 PM   #2
Andy10v
Andy10v's Avatar
Are your ones seized?
I have had good success freeing them off. Removing the caliper from the car, clamping it in a vice, remove the return spring, then lever the actuator arm (only comes up about a centimetre) clean and lube the shaft. Repeatedly forcing the shaft in and out, cleaning and lubing, then turning it to force the piston out. Again levering the arm up to clean and re lube. Winding the piston back in and repeat.
Starting with a set of callipers that the handbrake mechanism had to be hammered to move it took about 20 minutes to have them completely free and working again.
2005 350z GT
Sold-1993 ABY coupe
Old 27-12-11, 12:25 AM   #3
Tonks4x4
Tonks4x4's Avatar
I have never had any success with that I have even tried to fully strip them but you need a special set of circlip pliers to get the last piece of mechanism out. When I have tried to free the arms they have all just gone floppy and no longer push the pistons out
http://www.tonks4x4.com
Old 27-12-11, 12:39 AM   #4
Andy10v
Andy10v's Avatar
I didn't use to bother trying to free them off as I had been told it didn't work/they would just seize up again very quickly.
However read about somebody freeing them off, and told my dad, he freed off my old s2 ones for his 100 (they were solid, not leverable at all, needed a sizeable hammer to start them moving, and they have been on his car for a while now.
I have also done another two sets like that which work perfectly.
I think it is worth a shot (for me anyway) as it is quick and doesn't cost anything. Now worth paying a garage though, and if they did just seize again it could be a pain.
2005 350z GT
Sold-1993 ABY coupe
Old 27-12-11, 12:54 AM   #5
nimz
nimz's Avatar
Fancy giving it a try on Wednesday Bri?
I am here: http://maps.google.com/maps?ll=53.440961,-0.718497
Old 27-12-11, 01:05 AM   #6
Andy10v
Andy10v's Avatar
Link (pictures are still there, you may need to click on them to see them though).
http://www.s-cars.org/postnuke/modul...rder=0&thold=0
2005 350z GT
Sold-1993 ABY coupe
Old 27-12-11, 12:06 PM   #7
yeti
My CQ ones were sezied solid and I sent them to these for a refurb
http://www.biggred.co.uk/
3 days later they were back with me, painted up, shiny and working fine for about £130.
2003 Cors-arrrgh
