Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,119 Currently Active Users: 1743 (1 members and 1742 guests) Welcome to our newest member, BuddyInons |
Slimer is using a lotsof coolant but no liquid on the ground
oil is fine not turned into mayo it's nice and clean Ive checked the most obvious things but does anyone know if there is some weird and wonderful thing that could be imitating the symptons of a head gasket on it's why out thanks guys
Audi the ride of your life |
Heater matrix? Carpets damp?
Banned
Coolant can 'burn' and exit through the exhaust pipe. If the antifreeze mix is correct, burnt coolant will smell acrid and 'sharp'. When it gets bad, you'll see white smoke.
there might not be anything on the floor and no signs of split hoses but have another careful look, especially on cold mornings when steam might be more obvious and on the underside of the hood for any stains etc.
Banned
Actually, you need your friendly mobile Audi expert to pop round with a coolant pressure tester:
http://www.isham-research.co.uk/quat...ges/19-170.bmp You won't find small leaks on a hot engine - the coolant evaporates at source. |
Ive got no damp carpets, no steam and no white smoke so only the usual suspect to be honest boo hoo
#7 | |
![]() John. |
How often is it 'always emtpy'? Is this a check ever time you drive? Or once a week?
Is the top of the expansion tank clean? Or are there traces of coolant deposits? are you topping up with proper coolant mix?
One thing that's sometimes overlooked is the cap. If it doesn't hold pressure then the coolant's going to boil at 100 degrees and it'll perculate away. Pressurising the system raises the boiling point.
J. |
Thought that so ADE's have ordered a new cap for me and are going to test it.
so decided to take to garage today pressure tested just got a text it's fine so he's gonna have a look and replace a few hoses for me and the cap and then run it and see what happens so I will keep you posted.
