Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Coupe GT5S Fitting anti roll bar bushes
Old 13-07-11, 08:15 PM   #1
Si_CoupeGT
Default Coupe GT5S Fitting anti roll bar bushes
Hi all, does anyone know how to fit the drop link bushes into the front anti roll bar on an 1985 Coupe? I've tried with a vice, with sockets/threaded bar and my local garage has tried with their press but no luck.
Here's a pic of the bush I'm changing, I've got this one out but can't get the new one in
Thanks in advance
Si
Si_CoupeGT is offline   Reply With Quote
Old 13-07-11, 08:21 PM   #2
they shouldn't be that difficult to get in. I used a G clamp and plenty of washing up liquid on my subframe bushes and they went in quite easily.
Old 13-07-11, 08:22 PM   #3
SteveT63
SteveT63's Avatar
Put the bar in the vice. Boil the kettle, put the bush in a mug and pour on hot water, leave to soak for a few minutes, take a couple of small screwdrivers remove the bush from the water and with alot of care, use the screwdrivers to persuade the bushes in.
T85 1985 90quattro I5 20vT
T81 1983 80 Sport Red
T81 1983 80 Sport Silver
Old 13-07-11, 08:52 PM   #4
4v6
Heres how i did mine.
http://www.classic-audi.co.uk/forum/...ad.php?t=12838
Old 13-07-11, 09:04 PM   #5
Or buy powerflex ones, they are in two parts.
Old 13-07-11, 09:29 PM   #6
Si_CoupeGT
Thanks for the advice all! It's very much appreciated, think I'm going to give 4v6's approach a try next as it seems the easiest way to go.
Old 14-07-11, 09:48 PM   #7
Si_CoupeGT
Finally managed to get the bushes in after making up a tool similar, (if not quite as elegant) as 4v6's. If anyone else needs to do this job it's the way I'd recommend. Many thanks for the help everyone
