Classic Audi » Community » General Chat » WR engine intake
Old 13-08-08, 05:17 PM   #1
Default WR engine intake
how do these measure intake air volume?
mine starts first time but now doesnt want to run so you need to keep the revs up.... when/if it stalls more often than not it wont start, it will turn over but not fire.... leave it 10-15 mins and it starts up first time!!
I was reliably (!!!) informed by Seditas Motors in Prerstwick that I need a replacement warm up regulator valve.... so after getting a factory refurbished one and changed it... guess what.. nothing different!!
so..... is it worth removing the fuel metering head/plenum chanber, inlet manny andn the ex manny which has a small leak when cold anyway?
Colin4wd is gonna look at it over winter for me which starts on the 24th August this year!!
He says he will transfer parts from his quattro until he gets the same problem I have on his then at least corner the fault(s).
Any usefull suggestions where to start and look at first are most welcome.
t.i.a
Rich
Old 13-08-08, 05:24 PM   #2
t.i.a
Rich
Usefull suggestions Richard LOCATE the prob before you or Colin take bits off.......you will end up in more trouble than you are in if you do that
Old 16-08-08, 08:43 AM   #3
finding the problem in the first place is the problem... its nothing obvious!!
metering head fuel pressure delivery is next to check out.
ur quattro intake hose.......save money!!! Darron Edwards Engine 3 03-08-09 11:28 AM
How much for a 88 2.2 KV Engine poopcoupe Parts For Sale 5 20-01-09 01:29 PM
WN carb and intake manifold. 4v6 Parts Wanted 0 19-01-09 09:55 PM
1982 80 CD Air intake random small pipe dav Engine 8 25-11-08 10:44 PM
2.0 16V engine (6A) Tarka Parts Wanted 6 25-08-08 08:21 AM
