Classic Audi » Technical » Mech/Tech » Transmission » Lumpy Auto change
Prev Previous Post   Next Post Next
Old 30-06-11, 05:36 PM   #1
Bindinbear
Default Lumpy Auto change
My Coupe 2.3 auto changes quite violently, more so obvious when warm. Took it to a specialist and said the fact that its positive doesn't suggest a box' fault more ECU. So, I plugged in my kit and I'm getting two faults:-
00518- throttle position sensor (G69) sporadic signal outside tolerance and
0299- transmission range program switch (E122) spoardic- short.
is this the throttle position sensor?
If this is the sensor, it doesn't seem dirty??
Should i change the gearbox oil too?
I presume the second fault is something to do with the stick itself?
I don't know if its relevant but the temp gauge isn't working at the mo?
advice appreciated, thanks
Bren
Bindinbear is offline   Reply With Quote
