Classic Audi » Technical » Mech/Tech » Transmission » Auto swap to manual ?
Old 28-06-11, 11:06 AM   #1
Steve90q
Steve90q's Avatar
Lightbulb Auto swap to manual ?
Simple question here
Can you change an auto to manual ?? It would be quattro aswell if that makes a differance.
Easy job ?
Cheap job via a garage ?
Seen a couple of cars for sale but they are auto, so i was thinking about this
Cheers
Steve90q is offline   Reply With Quote
Old 28-06-11, 11:30 AM   #2
saint001
it can be done ,but it is a world of pain ,other than changing the gearbox ,theres the pedals ,throttle linkage etc .its been mentioned on here before -im sure some nice fellows will put up a linky
saint001 is offline   Reply With Quote
Old 28-06-11, 11:39 AM   #3
MadderThanMax
MadderThanMax's Avatar
My First question always when I see this is "How Good are you with a spanner??"
Its quite an undertaking and not for the faint hearted, however that said, it can be done and done successfully.
You would need to locate a suitable manual donor - ideally a manual car that way all the parts are there to swap, and you can take plenty of photographs of how the manual is set up in situ. The only thing I'm not sure of is - if its a new car, how does it affect the autobox ECU? Earlier Audis, yes you can swap including flywheel and fit a new clutch whislt you are there, then it a matter of swapping all across to the Auto car. Make sure you have a plentiful supply of trolly jacks, wooden blocks, 19, 17, 15, & 13 mm spanners to hand along with a few medium breaker bars (Just in case) then disconnect the battery (s) and go for it.
Take your time and don't go trying to be a Mclaren pit crew member as it will only lead to tears and once done Enjoy!!
Good Luck!
MadderThanMax is offline   Reply With Quote
Old 28-06-11, 11:40 AM   #4
stuartmmcfc
dont know where the link is but have to agree, it is really difficult/time consuming and expensive.
Whats wrong with an auto?
If the engines big enough it makes life much more relaxed
Old 28-06-11, 01:24 PM   #5
Steve90q
Steve90q's Avatar
Thumbs up
Good Luck!
Cheers guys
