Classic Audi » Technical » Mech/Tech » Engine » Centre two spark plugs unremoveable!
Old 07-04-11, 06:09 PM   #1
SteveCat
SteveCat's Avatar
Default Centre two spark plugs unremoveable!
Hey!
Was just swapping out the plugs today for a fresh set on my Coupe 2.0 16v
1 & 4 no probs using the usual 10mm plug spanner.
The centre two,it wont fit!
Now,as far as I know,theres only two kinds of plug size.The larger Ford type and the 10mm size.
Can anyone advise me if theres an extra slightly larger size I dont have??? ooer!
The 10mm socket just spins as if its not slid down over the hex at all.
Hmmmm
Mercedes E220 Sportline Coupe
Old 07-04-11, 06:11 PM   #2
A_N_Other
I had a Halfrauds plug spanner where the rubber insert was too big and didn't allow the plug spanner to reach the hex: just popped the rubber out and used the plug spanner a s a regular socket and pulled the plugs out with a magnet, or old bit of fuel pipe.
A_N_Other is offline   Reply With Quote
Old 07-04-11, 06:35 PM   #3
SteveCat
SteveCat's Avatar
Default .
Thanks man!
This one already has the rubber removed though.
Im already going bareback!
Old 07-04-11, 07:22 PM   #4
SteveCat
SteveCat's Avatar
Default .
Ah!
Never knew there were 4 different sizes of plug tool.
There is,and I dont have the 2 in the middle size!
Oh well.GSF it is then
Old 07-04-11, 09:02 PM   #5
Ben
The wheel nut removing box spanners other end is a spark plug removing socket.
1992 80 quattro 20vt
Old 07-04-11, 09:31 PM   #6
SteveCat
SteveCat's Avatar
Default .
Ah thanks Ben..
Alas,this car didnt come with a spare wheel let alone the spanner!LOL!
