Classic Audi » Technical » Mech/Tech » Transmission » V8 Prop Shaft removal- small snaggette
Old 20-02-11, 09:50 PM   #1
Hanuman
Hanuman's Avatar
Default V8 Prop Shaft removal- small snaggette
In the process of pulling the rear diff out of the donor car. Hit a snag. The bloody propshaft will not let go. 6 bolts attach it to the diff flange, and they all came out pretty easily. At the other end, same arrangement attaches to the gearbox (only, in this case, one of the bolts is shagged! Doh!!)
I can't see any damage/distortion to the mating flange. It is a little rusty, so I have some penetrating spray on it.
Thoughts/suggestions/what have I missed?
Old 20-02-11, 09:53 PM   #2
Gas Axe....
(heat).... Not scrappage....
Old 20-02-11, 09:55 PM   #3
Default If that doesn't shift it.
Then spray,some more.Heat might,draw it in?
KARL.
Old 20-02-11, 09:56 PM   #4
Hanuman
Hanuman's Avatar
Sadly, no gas axe available, and not likely to be.
Was thinking to attack it with my raychem gun tomorrow. That might work.
bloody typical- stuck solid one end, and a bugger bolt tuvver. Still, one or other should release tomorrow.
Old 20-02-11, 09:57 PM   #5
Default Sod's law.
Maybe carefully,dremmel it?
KARL.
Old 20-02-11, 10:31 PM   #6
Hanuman
Hanuman's Avatar
It's more a matter of convenience right now. If necessary, I shall simply drop the transmission on the drive and roll the car away over the top, and attack it at leisure.
Old 20-02-11, 11:00 PM   #7
quattrostyle
common 'problem' on all prop shafts I've removed. Take a piece of wood and a large hammer, place the wood on the head of the prop shaft and use the hammer to smash on the wood. Should come off without damaging it.
Old 20-02-11, 11:32 PM   #8
Andy10v
Andy10v's Avatar
Sounds like the same issue I had on my s2, all bolts removed and it would not drop off, I had to shock it free with a big hammer
2005 350z GT
Sold-1993 ABY coupe
Old 20-02-11, 11:58 PM   #9
Phil Payne
Banned
Angle grind the head off the bolt. There's plenty left to get hold of once it slides off and it will be less than finger tight anyway. BTDT.
On both ends it's quite normal to have to unseat the flange with a cold chisel and a few gentle taps. Getting the boss to release takes more force - I have a 500gm copper mallet. There's nothing holding it but stiction.
Old 22-02-11, 10:53 PM   #10
Rickman
both my front shafts and my prop to gearbox had a number of knackered bolts.
I used the angle grinder to remove the tops, then I unscrewed the remaining bits once the shafts were off.
Only a common thing when some muppet trys to use torq or allen drives... Damn Audi spline bolts...
Rickman is offline   Reply With Quote
