Classic Audi » Technical » Mech/Tech » Suspension & Brakes » German & Swedish Suspension Parts
Old 28-01-11, 10:51 AM   #1
james brazier
Default German & Swedish Suspension Parts
Has anyone got any thoughts on top mounts and wishbone bushes from GSF are they as good a quality as the dealer or Quattro corner???
james brazier is offline   Reply With Quote
Old 28-01-11, 11:31 AM   #2
KRIMZON
KRIMZON's Avatar
Its funny you should ask that....I went to my local specialist Vehicles who specialise in Audi's, BMW, Porshe etc.. They Work with the Audi dealers alot so I normally go there to get genuine parts (it's saves me going 20mile to nearest dealer) and they said to me that 98% of parts they use on the customers vehicles are GSF, and that they have never had a problem and highly rate the quality.....Well if it's good enough for them..Obviously there are a few parts that are geniune only but you get my drift.
IF IN DOUBT..HIT IT
KRIMZON is offline   Reply With Quote
Old 28-01-11, 11:33 AM   #3
try TPS, theyre bought over by Audi I think so eom parts
Old 28-01-11, 11:58 AM   #4
Martc
Black Coupe Collector
Martc's Avatar
TPS are for the trade so you will get a reasonable discount if you are (although some of the parts from Audi are criminally overpriced!), they have tightened up a lot on giving joe public a discount although I have seemed to be getting away with it so far....
95 UrS6
87 Coupe Quattro
Old 28-01-11, 12:15 PM   #5
gsf did although it may have changed have two priced for the greens, one with a cheap bearing and one with a quality german bearing. May have changed now. Pete supplied febi last time i had some last year, used the better gsf and petes and not noticed anything any better/worse. The last set got binned after apprx 18 months as there was slight play ( just before it was laid up last autumn )
Old 28-01-11, 04:44 PM   #6
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
Most of GSF parts are good but occasionally you get a duff part! I've come to realise that rubbers crack quite quickly on certain parts. Track rod end bushes have gone again and it's because of cheap rubber that doesn't last.
Old 28-01-11, 06:25 PM   #7
Gouldy
Gouldy's Avatar
i ordered my 2.1 CGT front wishbone and ball joint from them, both were wrong (even though i entered the reg plate)
then i ordered brake lines and track rod ends, and they were ok
Old 28-01-11, 07:27 PM   #8
Couperman
Smut Meister
Couperman's Avatar
I ordered front wishbone bushes for Gelbus from them, quoteing Reg No etc. After removing wishbone on drivers side I found that the bushes supplied were too big. Can't get correct bushes until Monday so am without a car for the weekend. Thanks a lot GSF.
Rod Inwood - Member 1467
Previously owned :-
