Classic Audi » Technical » Mech/Tech » Engine » Oil pressure warning.
Old 09-01-11, 04:01 PM   #1
scott 20v
Default Oil pressure warning.
On my 20v coupe quattro with 7a engine, the oil warning on the self check has started to come on when I switch on the ignition. The oil pressure gauge also shows about half a bar with the engine still off. When I start the engine oil pressure rises and light goes out as normal. Any ideas??
scott 20v is offline   Reply With Quote
Old 09-01-11, 04:10 PM   #2
BW2309
Banned
Most likely either oil pressure gauge or failed dash pod. The gauge reads off the large sensor where as the warning works off a low pressure switch in the same place. Be sure to physically check the oil pressure though, don't assume gauge right and warning wrong!! Best safe than sorry!!
All the 5 pots suffer from sludge build up in the sump and can starve the back cylinders crank journals.
Old 10-01-11, 05:50 PM   #3
scott 20v
Thanks. Everything is normal with engine running though!!
Old 10-01-11, 06:03 PM   #4
Pressure gauge showing something with engine off should be faulty sender. I had such thing in my A90q.
When u turn on ignition, is there only oil pressure warning from autocheck, or oil pressure warning light comes on as well?
Old 13-01-11, 08:03 PM   #5
scott 20v
Thanks. Just getting the oil light on the self check. I was thinking it might be a faulty sender or maybe just a bad connection. I think I'll give the sender connections a clean before I do anything else.
