Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » cq windscreen refit
Old 08-09-10, 08:27 PM   #1
moonwatcher
moonwatcher's Avatar
Default cq windscreen refit
Help needed, What's the sequence for refitting the screen, Is it fit the rubber to the body, then screen to rubber, any lubricant or any other secrets. I have two glass suction cups and a engine crane and was intending to lower the glass into position
Coupe Quattro 1985
Old 08-09-10, 08:41 PM   #2
rich.r
i would get a firm to fit personally
but if its any help i helped my uncle fit a screen to a dub a few years ago and it was rubber to screen put a bit of string inside rubber that fits to body offer up screen and pull rubber into place by using string to help
did that make sense
Old 08-09-10, 08:50 PM   #3
g40chris
g40chris's Avatar
yep done the string technique, tricky on your own but does work
g40chris is offline   Reply With Quote
Old 08-09-10, 09:08 PM   #4
rich.r
just rememberd one of us had to pull the string out as the other lent on the screen from the outside to push it in place
but i would still get a firm in i think especially if its an old screen
Old 09-09-10, 11:17 AM   #5
moonwatcher
Thanks for the info guys, will keep you up to date
Coupe Quattro 1985
Old 13-09-10, 06:24 PM   #6
Rickman
put the rubber on the glass.
start at the centre of the bottom and insert washing line leaving a few inch stuck out to pull from. When doing string ins I like to twist a loop in the centre of the top.
Place glass and rubber flat against the appature and start from one of the bottom pulls.
Go both ways across the bottom and then pull the twist at the top if u have made one...
The loop only stops the screen from trying to slide up when u drop the bottom corners in.
Rickman is offline   Reply With Quote
Old 13-09-10, 08:30 PM   #7
moonwatcher
cheers for that, I had heard of the string system but was not sure of the start and finish points
Coupe Quattro 1985
Old 14-09-10, 07:44 PM   #8
Rickman
where in cumbria are u... if its not that far from me I can come round for a brew and fit it for u..
taken from your profile - Interests.... Barrow AFC
If your in Barrow then your luck is in my friend.... lol
Old 14-09-10, 09:08 PM   #9
moonwatcher
Yes I am in Barrow, Park Drive, will PM you
Coupe Quattro 1985
Old 07-10-10, 07:41 PM   #10
ChrisG
ChrisG's Avatar
So was this successful?
