Classic Audi » Technical » Mech/Tech » Electrical problems » Windows and sunroof stopped working
Old 04-09-10, 09:15 AM   #1
ringoosmeg
ringoosmeg's Avatar
Default Windows and sunroof stopped working
Good Morning,
Got into my 1995 Coupe yesterday, and pressed the window button.....nothing, same on the passenger side....also the elctric sunroof has stopped working too.
OK.....so me thinks, logically look for the fuse, now, cant find an obvious fuse for them, so gets the big book of Haynes, which as normal was useless for this problem, but transpires according to it that there is four relays for the windows/sunroof including two emergency cut out relays.
Before I go gungho and attack the relay panel (by the where exactly is this panel under the dash), does any one have experience of this problem and can possibly offer a quick solution before I attack it with a 14lb sledge hammer.....
Many thanks in advance for any help/advice given
Best regards
Ringo
ringoosmeg is offline   Reply With Quote
Old 04-09-10, 09:43 AM   #2
Had the same problem on 2 B4 avants which I presume will have a similar set up.
And that was the relay which is under the dash behind a panel held in with 4 screws (maybe 6 but only 4 went back in!!). Think the relay unit number was either 363 or 383.
Old 04-09-10, 11:56 AM   #3
a6v6
a6v6's Avatar
Relay 363 the BIG one....Intermittant problem on my 94 Coupe too!!..
a6v6 is offline   Reply With Quote
Old 04-09-10, 12:28 PM   #4
Yup, pretty sure that was the one.
I got one off a chap of the s2 forum, swapped over and problem solved.
Old 04-09-10, 04:30 PM   #5
ringoosmeg
ringoosmeg's Avatar
Chaps,
thanks, I'll get one ordered, as its intermittant, as its working again today...gggggggr!
But no doubt it will play up again, so will order a new relay just in case.
Many thanks
Ringo
Old 04-09-10, 05:37 PM   #6
foxracing
foxracing's Avatar
Originally Posted by ringoosmeg View Post
Chaps,
Many thanks
Ringo
It's probably the thermal fuse under the drivers side parcel shelf, mine did this, when the inside of the car got hot the thermal fuse opened cutting power to the windows and sunroof, when the car cooled down everything was fine.
foxracing is offline   Reply With Quote
