Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Lowering throwing the rear end out of allignment...
Old 30-05-10, 03:55 PM   #1
doninphi
doninphi's Avatar
Default Lowering throwing the rear end out of allignment...
I noticed today while cleaning my new ride that the rear left wheel sticks out more than the right, looking underneath I now see why, basically the arm that runs diagonally from the rear beam is pushing it out the lower it goes.
So I'm now gonna have to shorten this arm to get the wheels even and the car straight again. Anyone else noticed this? Or do you all have crabs? Lol sorry I mean do you all run lowered 80's that crab?
I make vinyl STICKERS! Pm me for any design you want...
doninphi is offline   Reply With Quote
Old 30-05-10, 04:36 PM   #2
SteveCat
SteveCat's Avatar
Default .
To lower a car 100% correctly mate,you need to shorten that "Panhard Rod".
Its fairly safe to assume you cant buy them I guess,but can get one made up perhaps.
I just remember this info well from when I lowered a car I had once.The factory lowering kit was a kit comprising of the springs,shorter shocks,shorter anti roll bar links.
The rod will push the axle to one side as it compensates for the sideways movement of the axle IIRC.
Perhaps the bushes on your rear axle are also showing their true wear as there is more compression and stress on the rear axle and its associated componentage.
Sorry for the vagueness,its not the gin,I just havent needed to know this stuff for a while now,bit rusty old bean!
Steve
Mercedes E220 Sportline Coupe
Old 30-05-10, 05:04 PM   #3
doninphi
doninphi's Avatar
No you're exactly right, I just wondered if shorter ones were available! Didn't know the name of the rod either.
Think I'll whip mine off and chop/shorten it. Will have to guestimate how much!! will be conservative!
Old 30-05-10, 05:49 PM   #4
SteveCat
SteveCat's Avatar
Default .
OK,I have remembered how much to shorten mate.
If you lower 4cm=40mm,shorten the Panhard Rod by the same amount.
Glad to have been of assistance with your vintage beast,my man.
Steve
Old 31-05-10, 02:58 PM   #5
Rickman
chop the rod, re-weld in some chunky thread-bar and make it adjustable. Then if your not in the right place you can spin the nuts and take up any slack
Rickman is offline   Reply With Quote
Old 31-05-10, 03:44 PM   #6
doninphi
doninphi's Avatar
Now that is a hell of a plan! Might do that!
40mm reduction seems a lot, I'd hve thought it would be half the distance it is out by or there abouts. Eg if one wheel sticks out 20mm more than the other remove 10mm to even it, tho i suppose you'd have to take into account the angle it's at etc...
Thanks for the tip tho! Hope you're right! Will try for the adjustable bar idea...
Old 06-06-10, 10:00 PM   #7
Andy10v
Andy10v's Avatar
I am with this man, means you can get the car laser aligned and just tell the operator what nut to wind for "crabbing" adjustment
2005 350z GT
Sold-1993 ABY coupe
Old 15-06-10, 05:00 PM   #8
doninphi
doninphi's Avatar
See my other thread but if you plan to do this for a 50mm drop it's actually about a 10mm removal but I would totally recommend making it adjustable or else you'll struggle to get it bang on.
You'll also need the car jacked up on the axle so it's sitting at ride height only lifted up. Then get a mate to push on the car to allow you to get the bolt in!! Unless you make it adjustable while in position.
