Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Front Suspension Arm Woes
Old 01-05-10, 07:05 PM   #1
Default Front Suspension Arm Woes
Finally got the front suspension fitted up today. The plan was by the end of the evening to have the car sat back on all four wheels again ready to give her a good clean on Monday and start to look forward to enjoying summer.
Had a tough old fight getting the roll bar on (so much tension in that thing), managed to get my left hand pinned between the trolley jack and the car at one stage - don't ask but boy did I squeal.
Finally at 6pm I lowered her down ready to torque up the hub nuts and to clean the garage. Checked the suspension at the top mounts only to find both sides are sat proud but 2 -3mm. No probs i'll just tighten down the nuts...nope.
Took a closer look and it seems the peg nut is sitting proud of the top mount instead of being recessed in. Tried to tighten it down. No success. So unless anyone has any ideas it looks like the whole lot has to come back out again.
This is how both sides look. As soon as she's on wheels the mountings lift out
Removing the nut and cap shows the peg nut is sitting proud. It wasn't like this when I assembed the arms so I'm not sure why they both sit up.
Old 01-05-10, 07:21 PM   #2
Puglife
==>PUGSPORT!<==
Puglife's Avatar
How new are the top mount rubbers martyn? I had this on my CQ. The nut looks like its fully down, and any sag in the top mount rubber will allow the top cat to sit proud of the sturt top.
Old 01-05-10, 07:23 PM   #3
they are the ones that were taken off. These are the bit's I didn't change cos I thought they were ok. Maybe they weren't after all
Old 01-05-10, 07:25 PM   #4
Puglife
==>PUGSPORT!<==
Puglife's Avatar
I think I have two new ones (providing they are same as Quattro...) I'm about till monday evening if you want them martyn? That said they are only £12 new i think.
I'll be free as of thursday as well so if your struggling and need a pair of hands just shout
Old 01-05-10, 07:29 PM   #5
I would agree with pugsy , I have a spare pair of ur ones if you wan em too, they are a consumable on type 85s mart, done all mine last year and they last a handful of years tbh... In essence they will be donald ducked
Old 01-05-10, 07:33 PM   #6
Jay, you are a superstar and a gentlemen my friend
Thanks very much for the kind offer. I'll give Pete Reeve a call and order some new ones just to be sure I get the right ones. I'm just wary that often coupe and quatty stuff doesn't always cross over.
The donkey work isn't too bad, especially now it's all been taken to bits and cleaned up anyway so I should be ok.
Worst part is I hummed and ahhed over changing them and opted not to....idiot.
Thanks again.
Old 01-05-10, 07:37 PM   #7
Do you mean the concave caps,stick up proud 2mm????
If so,they should.
All 4 q90,s i,ve owned,the caps stand proud.
Is that what you mean?Mine are higher.
Old 01-05-10, 07:44 PM   #8
Just like that Karl. Are you sure thats normal cos I don't remember mine sitting proud like that when I took them off
Old 01-05-10, 08:09 PM   #9
I,m sure all mine,are(were)like that?Next time I,m at the unit I,ll look at my blue ones.
Maybe they weren,t tightened enough,before you took them off?
Old 01-05-10, 08:17 PM   #10
Baggee
Baggee's Avatar
I'm poppin' pver to my mom's after the match Mart. As mine are still the original ones I'll have a look and if I remember the camera I'll take a pic to confirm for you. Have ou looked in the Hayenes manual to see if it shows a pic in there?
