Classic Audi Technical Mech/Tech Engine » 2.2 KV Idle problems
Old 27-05-18, 07:00 PM   #1
Richi95
Default 2.2 KV Idle problems
Hi there,
Over the last 6 months I've been carrying out some work on my audi coupe so it has been off the road for this period of time.
Now the car is on the road it has developed quite a rough/lumpy idle after not being used for long. Over the last few weeks I've put in a new fuel pump as the old one was knackered, new HT leads, new spark plugs (bosch w6dtc), new bosch distributor cap and rotor arm.
My next steps were to replace the fuel filter. The intake boot that goes over the k-jet to the throttle body has got a slight tear in that, so I was going to replace that also, and clean out the throttle body etc at the same time.
It's okay on initial start up but after a minute or so it bogs down and starts to hunt around 500-750rpm. It doesn't cut out however.
Is there anything anyone else can recommend from experience?
Thanks in advance.
Richi95 is offline   Reply With Quote
Old 27-05-18, 07:11 PM   #2
Originally Posted by Richi95 View Post
The intake boot that goes over the k-jet to the throttle body has got a slight tear in that, so I was going to replace that also.....
Old 27-05-18, 07:14 PM   #3
Richi95
I shall change the intake boot in the week as soon as the new one arrives and report back! Fingers crossed that solves it
Old 27-05-18, 08:46 PM   #4
Duffy3074
If you’ve got unmetered air going in that tear, that will definitely be a problem
Old 28-05-18, 08:45 AM   #5
Mellis46
Aero Advocate
Mellis46's Avatar
In fact check any and all of the rubber hoses in and around the inlet. there are a few sneaky ones and any one of them which is melted or perished will contribute to a lumpy idle
-2012 A1 Sport TFSI / Glacier White (Sold)
-2017 A1 Sportback S-line TFSI / Scuba Blue
Old 28-05-18, 09:15 AM   #6
andya
andya's Avatar
Same as above, sounds like an air leak. Check all the hoses, the vacuum pipes, all of them! Hopefully it's the one you've already highlighted. If none of those help, try swapping over the isv relay (behind the passenger side glovebox).
1985 Coupe Quattro
1986 Coupe 1.8 weber carb
1987 Coupe 2.2 GT
Old 16-06-18, 06:08 PM   #7
Richi95
Just managed to get some time to work on the audi today, fitted the new intake hose and cleaned everything out and she runs great. Was definitely a vacuum leak!
Cheers fellas
