Members: 13,675 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 793 (19 members and 774 guests) Welcome to our newest member, uimovas |
17-01-20, 02:37 PM | #1 | |
audi 80 1991 steering pump
Hi folks - has anyone had problems with parts supply for audi 80 steering pump. I checked that the car was covered and ordered a pump. Physical size etc is good but it only has feed and return pipes. My car has 3 pipes - no idea what the third is for. Any ideas?
17-01-20, 02:47 PM | #2 |
I'm no expert, but where does it go to? What part in the engine bay? Is it an over-pressure fluid return pipe to the reservoir?
17-01-20, 06:36 PM | #3 |
I'm definitely no expert at all. Its the smallest of the pipes. I will see if I can add some photos to the thread. ed
21-01-20, 08:14 PM | #4 |
Ok I have the answer to the third pump connection. B3 Audi Quattros had a 2 stage pump fitted. 1st stage with a single connect is a brake servo pump. Behind that is a normal power steering pump with 2 connections. So now I either need a reconditioning kit or someone who can recondition the one I have.
21-01-20, 08:39 PM | #5 |
A lot of people get rid of the bomb and fit a servo from a non quattro car. Its a fairly easy conversion and is more reliable. Then you can use your new pump
21-01-20, 09:20 PM | #6 |
What engine is in your 80 ?
23-01-20, 05:50 PM | #7 |
Tractor Dave thats an ace idea - these are now like hens teeth and if you can find a supply they are about 800 plus to replace and I have found no one who reconditions them. If you can point me at a thread to do that conversion the problem is solved. Thanks for the reply. ed
23-01-20, 06:10 PM | #8 |
Try this. Related to S2 but yours is very similar. Error404 (Alex) can supply any bits you need.
https://www.s2forum.com/forum/techni...rvo-conversion |
26-01-20, 02:47 PM | #9 |
Thanks Dave the thread looks good apart from when I tried to download the PDF detail instructions the file location has either changed or has been removed. Dont sopose you have downloaded that file in the past?
26-01-20, 03:13 PM | #10 |
No I don't sorry. If you join the forum you can search through the technical pages and I'm sure the info you need will be there.
