Members: 13,621 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 821 (18 members and 803 guests) Welcome to our newest member, oposerokena |
08-06-14, 08:19 PM | #1 | |
how do you remove.......
.......wheel security bolts when you have lost the special socket....
Went to take wheels off cq and can i find special socket? Can i feck. Was hoping to fit the powerflex black track bushes. Doh!
08-06-14, 08:26 PM | #2 |
Either drill/easiout or sacrifice a socket (x4) with a large mallet.... Either way, things will be broken....
08-06-14, 08:31 PM | #3 |
I don't know how effective these are?
http://www.halfords.com/webapp/wcs/s...egoryId_255216 Can be found cheaper than this if you shop around. |
08-06-14, 08:45 PM | #4 | |
All you need to do is excerpt more force in the undoo'y direction of the bolt than the crud/corrosion and tightenupski torque in the opposite direction.... Brutus ignoramus tends to be the successful option generally...
08-06-14, 08:48 PM | #5 |
Machine mart do a kit but I've heard varying degrees of success ...
08-06-14, 08:49 PM | #6 |
These are what I use on a weekly basis....
Made by Irwin Tonks4x4 - The Land Rover Specialist
http://www.tonks4x4.com |
08-06-14, 09:50 PM | #7 |
^^those are what the local tyre shop used on a car when the key for the locking bolt failed. Worked a treat.
08-06-14, 11:48 PM | #8 |
This the the lock in question
As you might be able to see the outer collar slides round the inner section so doubt the suggested methods so far will work. Hoping I can locate a replacement key somewhere.... Sure its in a safe place, just don't know where....
09-06-14, 03:36 AM | #9 |
Morning
that looks like an Audi locking wheel bolt if it is go to local dealer ask to get new socket. they have the kit and should be able to order new one Goodluck cheers john |
09-06-14, 05:22 AM | #10 |
As JML. This happened with my S4. The local dealership had a master set, and the correct one was found, to undo the bolt there and then, and a new one could be ordered.
