Members: 13,905 | Total Threads: 40,056 | Total Posts: 470,827 Currently Active Users: 562 (20 members and 542 guests) Welcome to our newest member, ahiwmqeze |
28-08-13, 08:41 PM | #1 | |
jogi
B2 fuel tank
I am still experiencing fuelling problems with my car. The latest thought is that somehow the fuel tank is restricting flow.
Has anybody please got a schematic of the 85 B2 fuel tank, particularly showing the pick-up and return positions. This information could stop the fuel tank having to be removed Many thanks
28-08-13, 09:39 PM | #2 |
If you have air compressor available, take off the hose from fuel pump, blow the air in and quickly place it back on pump. I'm experiencing similar problem - if I will run out of fuel, afterwards the tank will have some restriction which will cause some shaking @ WOT. The only strange thing - I cleaned my tank throughly a year and half ago. Unfortunately fuel outlet is on the opposite side to level sender, so when taking a picture through that opening, it couldn't be seen. Will have to put some webcam in in the future - currently it just makes me make sure I won't run out of the fuel
28-08-13, 09:42 PM | #3 |
are you using the standard fuel tank with a standard fuel pump Chris?
28-08-13, 09:44 PM | #4 |
jogi
I have 2 Bosch 044 pumps working together.
They draw the fuel into a swirlpot but it sometimes sounds as if I am over-running the supply. Would still like more info, phot's from anyone that has cross sectioned one of these tanks or schematics if available @ Coxy - Standard fuel tank
28-08-13, 09:52 PM | #5 |
I know urq tanks have some kind of filter at the bottom.only way of cleaning/replacing it is to cut the tank open then weld it back up.not sure if n/a t85s have the same filter or not though
29-08-13, 07:08 AM | #6 |
I had fuelling problems with my CQ type 85 Chris because the car stood for a couple of years without being used. Eventually put a clean tank in out of a 90 quattro type 89 and the problem seems to be solved.
However this might not be an answer to your question, your car also hasn't been used for a while and may suffer the same problem. The 90q type 85 is unique though as far as I'm aware and not interchangable with a newer item. |
29-08-13, 08:15 AM | #7 |
jogi
Thanks chaps.
None of this is sounding good. Sounds like the tank may well have to come out. A schematic, some drawings or some photo's would still prove invaluable though.
30-08-13, 06:23 AM | #8 | |
30-08-13, 09:23 AM | #9 |
80q addict
I'd imagine they're still like the UR with a gauze inside. Also, I think Micky's running problems turned out to be a blocked/restrictive fuel return.
I considered a full tank derust and then POR15 tank seal refurb for my 80q, but in the end I decided that the tank sealer could block the internal filter. In the end I just rinsed it out with loads of fresh fuel until the flow was clear. |
30-08-13, 10:04 AM | #10 |
jogi
Thank you kindly Val. THose pics could prove most helpful.
However, sounds like tank will have to come out to clean it properly
