Members: 13,657 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 812 (20 members and 792 guests) Welcome to our newest member, adokofunuyi |
25-08-11, 06:38 AM | #1 | |
200 turbo 2B engine problems
I have an engine from a 200 turbo auto with 2B engine code. I did not get the ecu with it and have tried to get it running with the flywheel , wiring loom and ecu ( MAC 05) from an earlier 200 but it wont spark. All outputs have been checked and are at the correct voltage.
Does anyone know if the pins on the flywheel are at the same position for the 2B and what ecu I should be using if the 05 is no use? Cheers |
25-08-11, 08:42 AM | #2 | |
Banned
I think I'd be tempted to go for a MAC12D. |
25-08-11, 09:04 PM | #3 |
Phil,
Cheers for the reply but I don't have the 200 bellhousing either. I am using the box from an early 80 quattro with cut out for the flywheel sender. |
