Classic Audi Technical Mech/Tech Engine » Ur quattro flywheel sensors
Old 12-09-21, 02:45 PM   #1
lefthooker
Default Ur quattro flywheel sensors
One plugs into the ECU loom, the other into the engine loom. Not sure which way around they should be as the connections appear to be identical, can anyone help?
Car is a 1981 WR.
Old 12-09-21, 08:40 PM   #2
Colin Aitchison
Colin Aitchison's Avatar
They both got back to the ECU, G4 - Ignition timing sensor, fits into the left rear of the engine block and looks for the timing pin on the rear of the flywheel , G28 - Engine speed sensor, fits into the top front edge of the gear box and counts the flywheel teeth, never fitted them round the wrong way, so can not confirm if that causes problems.
Old 13-09-21, 04:06 PM   #3
lefthooker
Thanks for that. Found that they do indeed both go back to the ECU
Still need to find out which is which, probably going to end up a case of trial and error.
Old 13-09-21, 04:22 PM   #4
Colin Aitchison
Just had a look at the wiring diagram, G4 and G28 connect to the ECU pins as follows, G4 connects to pin 12, 13 and 25, 25 is the earth shield, 12 and 13 are the siginal wires, G28 connects to pin 11, 24 and 23, 23 is the earth shield, 11 and 24 are the siginal wires. There are two or three ways to test this with an AVO. but all involve removing the cable connector from the back of the ECU for testing.
Old 13-09-21, 04:33 PM   #5
lefthooker
That's excellent info. Thanks very much for your help.
Old 13-09-21, 05:01 PM   #6
They're normally colour coded.
G4 is black
G28 will be grey
1988 90 quattro 2.6 TSR
1991 90 quattro
Old 14-09-21, 12:31 PM   #7
lefthooker
G4 is black
G28 will be grey
Thanks for that
