Classic Audi Ľ Technical Ľ Mech/Tech Ľ Engine » Cooling
Old 08-09-21, 07:32 AM   #1
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
Default Cooling
My Wr has over time developed a tendency to run a bit hot, all service items are up to date and pretty new, water pump etc new thermostat also. Iím leaning toward maybe the radiator is not being quite so efficient, it is nearly forty years old. Iím going to point the infra red thermometer at various points to see how much heat it is actually dissipating, if anyone else could do the same for comparison, I would be very grateful. Thanks
http://www.oesems.co.uk/
Old 08-09-21, 08:56 AM   #2
BackintheFold
BackintheFold's Avatar
When was the last time the radiator was flushed, fully, backwards and forwards and with the inside heater turned to hot?
I would suspect it is a bit blocked/sludged up and a good flush would help.
1985 WR ur Quattro (2nd time around)
1988 MB ur Quattro (Phil Payneís)
2006 A3 (daily drive)
Old 08-09-21, 09:05 AM   #3
I might get a chance to use the Ur in the next couple of days and if I do, I will temp test the radiator.
Isimmo is online now   Reply With Quote
Old 08-09-21, 12:43 PM   #4
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
Iím not sure how good the flush was, but a couple of years ago I gave it a reasonable go with the hose pipe. The coolant is clean, and stays clean, I havenít tried any type of radiator flush or anything, and I wonder if it is likely a lime scale problem ? That might be a bit hard to shift ?
Old 08-09-21, 12:51 PM   #5
BackintheFold
Might be as simple as needing a new radiator temperature sensor? Perhaps that is getting scaled up.
I bought 25 litres of distilled water to use as the water round here is VERY hard!
Old 08-09-21, 09:39 PM   #6
SwallownAmazon
SwallownAmazon's Avatar
Sounds like you need a mains water softener. First job we did when we moved into our house in Tonbridge where the water is also very hard coming from deep chalk aquifers.
Old 09-09-21, 12:28 AM   #7
BackintheFold
Yup! Got one. Lovely soft showers!
Old 09-09-21, 06:46 AM   #8
tractor Dave
I used a flush that is safe for all metals\rubber etc. Left it in for a long run and flushed twice afterwards. Lots of crud came out.
Old 09-09-21, 07:08 AM   #9
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
What was that Dave ? Could well be worth a try, lack of use on my part doesnít help I donít think.
Old 09-09-21, 08:11 AM   #10
tractor Dave
I used this one.
I have done both of my classic tractors and the S2 with it and no issues.
