Classic Audi » Classifieds section » Parts Wanted » Ur warm up regulator fuel pipes
Old 11-09-21, 04:55 PM   #1
BackintheFold
BackintheFold's Avatar
Default Ur warm up regulator fuel pipes
Mine are both a bit rusty at the fuel distributor end.
Probably fine for another few years but I would not like them to split while driving!
Anybody got two spare and would like to sell both please? Or can they be re-crimped?
1985 WR ur Quattro (2nd time around)
1988 MB ur Quattro (Phil Payne’s)
2006 A3 (daily drive)
Old 11-09-21, 11:24 PM   #2
You may be in luck. I'll have a search
1988 90 quattro 2.6 TSR
1991 90 quattro
mikes2 is online now   Reply With Quote
Old 12-09-21, 07:47 AM   #3
BackintheFold
Thanks Mike. You’re a star!
I also wonder if the warm up regulator is the reason my car starts like an absolute pig, but settles down to an excellent idle and runs fine after 10-15 seconds or so (I’ll time it properly today).
I’ve disconnected the cold start valve but the smell on start up is very rich.
On a long run I’m getting 33mpg, and the plugs do look lean.
I don’t have a pressure tester to check WUR operation-would you say that’s next step?
I have to be careful removing the fuel pipes as they are not brilliant.
Thanks again!
Old 13-09-21, 07:12 PM   #4
Found them - feed and return. PM me
For fuel pressure, it should start low around 1.2-1.5 bar and increase when warm to 3.3-3.8 bar. I'm not 100% sure on the numbers for your engine.
Make sure everything else is in good order. Fuel delivery, injectors not leaking, check valve working correctly, accumulator diaphragm good.
I got my tester from a German seller and it was easy to setup and confirmed a warm up regulator fault straight away.
1991 90 quattro
Old 13-09-21, 09:29 PM   #5
BackintheFold
Will send pm...
I am scheduled to check the injectors tomorrow.
I have 5 glass pots for the ends to sit in for 24 hours!
I will look for fuel gauge later too.
Thanks again!
